My domain is: almanalmani.xyz
I ran this command:Project Fog
Project Fog
Type your domain: almanalmani.xyz
Make sure: 164.92.243.239 is connected to your almanalmani.xyz
Do you want to continue? yes
☁️☁️☁️ Project Fog ☁️☁️☁️
ReType your domain: almanalmani.xyz
Requesting a certificate for almanalmani.xyz
Domain: almanalmani.xyz
Detail: 185.83.214.222: Invalid response from http://almanalmani.xyz/.well-known/acme-challenge/X0djSGCj8kY3GDaAnpaeVPuaSFFFL-jGayAiOvpeeio: 404
ubuntu
22.04
digitalocean
or certbot-auto --version
if you're using Certbot):
