I have a web server with viber bot in it. But to use it I need SSL certificate, so I installed the certbot and made request for my domain bot.tke.ck.ua. Certbot said "congrats", and so I pasted the path for certs in server httpsOptions:
const https = require('https');
const port = 80;
// Viber will push messages sent to this URL. Web server should be internet-facing.
const webhookUrl = 'bot.tke.ck.ua';
const httpsOptions = {
key: fs.readFileSync('C:/Certbot/live/bot.tke.ck.ua/privkey.pem'),
cert: fs.readFileSync('C:/Certbot/live/bot.tke.ck.ua/cert.pem'),
ca: fs.readFileSync('C:/Certbot/live/bot.tke.ck.ua/fullchain.pem')
const server = https.createServer(httpsOptions, bot.middleware()).listen(port, () => bot.setWebhook(webhookUrl))
But after running the server I'm only getting a lot of node exceptions:
[nodemon] starting node viber_bot.js
(node:3132) UnhandledPromiseRejectionWarning: #
(Use node --trace-warnings ...
to show where the warning was created)
(node:3132) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict
(see Command-line options | Node.js v15.11.0 Documentation). (rejection id: 1)
(node:3132) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
In other hand, whem I'm using ngrok for SSL, there is no problem.
What I'm doing wrong, and what I need to do?
