My domain is: beansincup.se
https://www.beansincup.se/ works fine but when you try to visit http://beansincup.se/ the certificate wont work. What is wrong? Do I need to add another certificate for beansincup.se/. I have several sites and I never hade any problems with this.
Yes, you need your cert to have both beansincup.se and www.beansincup.se
I don't know how you do that in EasyEngine. It looks like it should be setup by EE per their docs here. Maybe ask them if not sure.
One thing that may have prevented it from working is failure connecting to http://beansincup.se. That should be working before an HTTP challenge will work
