Hi!
I am use centos 8.3.
The problem is in certbot 1.13.0 installed with the of snap, as well as in version certbot 1.12.0 installed using the EPEL repository.
This problem did not exist in certbot-auto, but now certbot-auto does not work (
I cannot issue certificates for my sites:
Detail: Invalid response from
https: //domain/.well-known/acme-challenge/d8oLXK4fO_xVYD7w1UvwHZ2v1UNc4TGzvz_Sptb8JfU
[address]: " \ r \ n 404 Not
Found \ r \ n \ r \ n
404 Not
Found
\ r \ nnginx \ r \ n "
In my case, nginx has a lot of small configuration files .conf, it looks like this is causing problems for certbots. Now I have 1000+ config files, if I reduce them to about 500, then the certificate is issued normally.
