Problems with generate certificates for GitLab nginx server on VirtualBox
My domain is: intenso-gitlab.pl
I ran this command: sudo certbot certonly --webroot --webroot-path=/var/www/letsencrypt -d intenso-gitlab.pl
The operating system my web server runs on is (include version): ubuntu 16.04
Hi guys,
i had installed GitLab EE on my VirtualBox Ubuntu 16.04. Also, i bought domain intenso-gitlab.pl. Next in Virtualbox i had activated second with host only settings - this allow me to receive ip address and assign it to my domain. When i create self signed certificate everything is ok i can access to my domain by https but i would like to use let’s encrypt option. So i proceeded this tutorial:
https://www.digitalocean.com/community/tutorials/how-to-secure-gitlab-with-let-s-encrypt-on-ubuntu-16-04
but when i call this command:
it throw me strange exception:
http-01 challenge for intenso-gitlab.pl
Using the webroot path /var/www/letsencrypt for all unmatched domains.
Waiting for verification…
Failed authorization procedure. intenso-gitlab.pl (http-01): urn:acme:error:unknownHost :: The server could not resolve a domain name :: No valid IP addresses found for intenso-gitlab.pl
    Domain: intenso-gitlab.pl
    Type: unknownHost
    Detail: No valid IP addresses found for intenso-gitlab.pl
Maybe somebody will have any advice how to solve this problem?
The A record for this domain points to a local IP address (192.168.56.101). This is not accessible from the public internet, and is an invalid setup. Using HTTP-01 challenges, your server must be publicly accessible.
If you cannot modify this, then you are still able to use the DNS-01 challenge type, however the automation of that process is highly dependent on your DNS provider allowing programmatic access. Without that, you would need to manually intervene to create the required TXT entries every time you renew.
Ok so conslusion is that when I assign Public ip to this sever it solve my problem?
Yes, assigning a public IP address should solve your problem.
