My client’s site, granicaeditor.com, will secure it with your certificate generated with Acme software, win-acme.v2.1.5.742.x64.pluggable.
I use IIS v.7, everything is fine but after the first renewal on May 25/2020, the closed padlock no longer appears in the browsers and it indicates a site that is not totally safe. I need help, I have little experience with SSL and certificates.
The certificate was successfully renewed without problems and the certificate is displayed in browsers correctly, valid and dated.
You have unsecured content on your site. I.e., content having an URI starting with http://
in stead of https://
You can use the Console of your browser to identify those.
Also, unrelated, your site using just the base domain name gives a “Bad Request (Invalid Hostname)” error when loaded through HTTP. The www
subdomain returns a redirect to the HTTPS site.
Thank You, fix the problem.
