My domain is: elk2.endesarrollo.ovh
I'm working with latest Elasticseacreh and kibana version 8.4
/usr/share/elasticsearch/bin/elasticsearch-reset-password -u elastic
18:47:31.605 [main] WARN org.elasticsearch.common.ssl.DiagnosticTrustManager - failed to establish trust with server at [91.121.226.53]; the server provided a certificate with subject name [CN=elk2.endesarrollo.ovh], fingerprint [d3432f5a03043e533bd1a7a1aeabce8964bd1ac2], keyUsage [digitalSignature, keyEncipherment] and extendedKeyUsage [serverAuth, clientAuth]; the session uses cipher suite [TLS_AES_256_GCM_SHA384] and protocol [TLSv1.3]; the certificate has subject alternative names [DNS:elk2.endesarrollo.ovh]; the certificate is issued by [CN=R3,O=Let's Encrypt,C=US]; the certificate is signed by (subject [CN=R3,O=Let's Encrypt,C=US] fingerprint [a053375bfe84e8b748782c7cee15827a6af5a405] {trusted issuer}) signed by (subject [CN=ISRG Root X1,O=Internet Security Research Group,C=US] fingerprint [933c6ddee95c9c41a40f9f50493d82be03ad87bf] {trusted issuer}) which is issued by [CN=DST Root CA X3,O=Digital Signature Trust Co.] (but that issuer certificate was not provided in the chain); this ssl context ([xpack.security.http.ssl (with trust configuration: PEM-trust{/etc/elasticsearch/certs/chain.pem,/etc/elasticsearch/certs/cacert.x1.pem,/etc/elasticsearch/certs/cacert.r3.pem})]) is not configured to trust that issuer but trusts [2] other issuers ([CN=ISRG Root X1,O=Internet Security Research Group,C=US, CN=R3,O=Let's Encrypt,C=US])
java.security.cert.CertificateException: No subject alternative names matching IP address 91.121.226.53 found
at sun.security.util.HostnameChecker.matchIP(HostnameChecker.java:165) ~[?:?]
Config on my elasticsearch use. code below
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
network.host: elk2.endesarrollo.ovh
xpack.security.enabled: true
xpack.security.enrollment.enabled: true
xpack.security.http.ssl:
enabled: true
key: certs/privkey.pem
certificate: certs/fullchain.pem
certificate_authorities: [
"certs/chain.pem",
"certs/cacert.x1.pem",
"certs/cacert.r3.pem"
xpack.security.transport.ssl:
enabled: true
verification_mode: certificate
"certs/chain.pem",
cluster.initial_master_nodes: ["elk2.endesarrollo.ovh"]
http.host: 0.0.0.0
All certificates on my server they are obtained with cerbot, and copied to the elasticseacrh directories with a command, which I use in /etc/letsencrypt/renewal-hooks/deploy/elastic-deploy.sh in such a way that it copies the files in the two certificate repositories of Elasticsearch and Kibana,
But there is no way... I always get the above or below error
Apreciate help.
