My domain is: poillion.com
I ran this command: certbot --apache
certbot certonly --webroot -w /var/www -d www.poillion.com -d dev.poillion.com -d poillion.com
I apparently reached my attempt limit as I got the "There were too many requests of a given type" error. So I can't give the output from the ssh command line at the moment. But it's the basic same error as what 'Let's Debug' is telling me:
[ANotWorking](https://letsdebug.net/www.poillion.com/902005#ANotWorking-Error)
ERROR
www.poillion.com has an A (IPv4) record (72.200.213.203) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
A timeout was experienced while communicating with www.poillion.com/72.200.213.203: Get "http://www.poillion.com/.well-known/acme-challenge/letsdebug-test": context deadline exceeded
Trace:
@0ms: Making a request to http://www.poillion.com/.well-known/acme-challenge/letsdebug-test (using initial IP 72.200.213.203)
@0ms: Dialing 72.200.213.203
@10001ms: Experienced error: context deadline exceeded
My web server is (include version): Apache (latest version)
The operating system my web server runs on is (include version): Ubuntu Server 20.04 LTS
My hosting provider, if applicable, is: netfirms
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): No. I am using netfirms only for DNS entry. The DNS entries setup in the netfirms control panel are:
A dev (my ip)
A www (my ip)
A * (my ip)
A @ (my ip)
or certbot-auto --version
if you're using Certbot): certbot 0.40.0
And finally my /etc/hosts file:
127.0.0.1 localhost
127.0.1.1 poillion poillion.com www.poillion.com
I don't understand what I'm doing wrong. Let's Debug and the cli tell me they're getting a timeout. But it seems to be resolving just fine within my LAN. I know that's not helpful, but I don't know why it's not accessible from the internet. I have port forwarding setup on my router as well. I connect via ssh from external networks to the server all the time. Anyone have any ideas on what to check?
Thank you!
lorewap3
