Simulating renewal of an existing certificate for sebastiandetering.com
http-01 challenge for sebastiandetering.com
Challenge failed for domain sebastiandetering.com
Failed to renew certificate sebastiandetering.com with error: Some challenges have failed.
The following simulated renewals succeeded:
/etc/letsencrypt/live/peertube.sebastiandetering.com/fullchain.pem (success)
The following simulated renewals failed:
/etc/letsencrypt/live/sebastiandetering.com/fullchain.pem (failure)
That's the easiest part to check: check if the IPv4 and IPv6 addresses resolved by DNS are actually the IP addresses of the server. If that's the case, then DNS is not the issue. If that's not the case, then DNS is an issue. (Maybe not THE issue though, there may be more issues elsewhere.)
Chances are it's a misconfiguration in your webserver as @rg305 and @9peppe also already pointed out.
I am almost certain the rails server is not listening on IPv6 since I did no setup on that end.
root@vultr:~# cat /etc/nginx/sites-enabled/rails-demo
upstream rails-demo {
server unix:/home/rails-demo/app/shared/unicorn.sock fail_timeout=0;
server_name sebastiandetering.com;
root /home/rails-demo/app/current/public;
location /assets/ {
gzip_static on; # serve pre-gzipped version
expires 1M;
add_header Cache-Control public;
try_files $uri @app;
location @app {
proxy_set_header Host $http_host;
proxy_redirect off;
proxy_pass http://rails-demo;
ssl_certificate /etc/letsencrypt/live/sebastiandetering.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/sebastiandetering.com/privkey.pem; # managed by Certbot
#server {
# listen 80;
# server_name www.sebastiandetering.com;
# return 301 http://$host$request_uri;
if ($host = sebastiandetering.com) {
} # managed by Certbot
listen 80;
Above is my nginx config for the rails-demo server.
Does anyone know how to get this set up correctly, or if I dont want to deal with IPv6, a way to just disable it altogether?
