please answer the following questions. That’s the standard template of #help
Challenge failed for domain speedtest.redeshibridas.com.gt
Attempting to renew cert (speedtest.redeshibridas.com.gt) from /etc/letsencrypt/renewal/speedtest.redeshibridas.com.gt.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/speedtest.redeshibridas.com.gt/fullchain.pem (failure)
Visible Content: Bad Request Your browser sent a request that this server could not understand. Reason: You’re speaking plain HTTP to an SSL-enabled server port. Instead use the HTTPS scheme to access this URL, please. Apache/2.4.18 (Ubuntu) Server at speedtest.redeshibridas.com.gt Port 443
And your https sends http content.
Is there a wrong (inverted) port forwarding? Or is the webserver configuration wrong?
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server. Apache/2.4.18 (Ubuntu) Server at speedtest.redeshibridas.com.gt Port 80
So find your webroot / DocumentRoot and use it:
certbot run -a webroot -i apache -w yourDocumentRoot -d speedtest.redeshibridas.com.gt
