Problems installing Certificate and not able to figure out what to do
Hey there,
i am sorry because of my possibly stupid question but i am not able to figure out what i am doing wrong and hope you to give me some hint. Also sorry for my bad english. :see_no_evil:
I want to install lets encrypt certificate on my server, using a tld and a subdomain.
These are the two vhost config files in /etc/apache2/sites-available
nextcloud.conf
<VirtualHost *:80>
        DocumentRoot /var/www/nextcloud/
        ServerName cloud.dennisbuehler.de
        ServerAdmin dennisbuehler@mailbox.org
        <Directory /var/www/nextcloud/>
                Require all granted
                AllowOverride All
                Options FollowSymLinks MultiViews
                        <IfModule mod_dav.c>
                          Dav off
                        </IfModule>
        </Directory>
        ErrorLog ${APACHE_LOG_DIR}/nextcloud-error.log
        CustomLog ${APACHE_LOG_DIR}/nextcloud-access.log combined
</VirtualHost>
and dennisbuehler.conf
<VirtualHost *:80>
	DocumentRoot /var/www/dennisbuehler/
	ServerName dennisbuehler.de
	<Directory /var/www/dennisbuehler/>
		Options Indexes FollowSymLinks MultiViews
          Require all granted
		AllowOverride None
     </Directory>
        ErrorLog ${APACHE_LOG_DIR}/dennisbuehler-error.log
        CustomLog ${APACHE_LOG_DIR}/dennisbuehler-access.log combined
</VirtualHost>
If i use
certbot --apache
i only can install a certificate for nextcloud subdomain but not for the tld. When i choose Redirect Certbot says..
Failed redirect for dennisbuehler.de
Unable to set enhancement redirect for dennisbuehler.de
Unable to find corresponding HTTP vhost; Unable to create one as intended addresses conflict; Current configuration does not support automated redirection
Both *conf files are enabled with a2ensite, 000-default.conf is disabled with a2dissite..
...and i do not understand what i am doing wrong or what i have to change. Perhaps someone is kind to help me. i would be really thankfull.
Greetings
Dennis
Hi @dtm,
Is it possible that your config files are not being included? Can you run apachectl -t -D DUMP_VHOSTS to make sure?
until we can see:
You say:
But what is shown in?:
ls -l /etc/apache2/sites-enabled
Hey @schoen @rg305 thank you so much for trying to help me.
ls -l /etc/apache2/sites-enabled says..
total 0
lrwxrwxrwx 1 root root 37 Mar 21 19:16 dennisbuehler.conf -> ../sites-available/dennisbuehler.conf
lrwxrwxrwx 1 root root 33 Mar 20 19:23 nextcloud.conf -> ../sites-available/nextcloud.conf
lrwxrwxrwx 1 root root 50 Mar 11 12:00 nextcloud-le-ssl.conf -> /etc/apache2/sites-available/nextcloud-le-ssl.conf
apachectl -t -D DUMP_VHOSTS says...
VirtualHost configuration:
*:443                  cloud.dennisbuehler.de (/etc/apache2/sites-enabled/nextcloud-le-ssl.conf:2)
*:80                   is a NameVirtualHost
         default server dennisbuehler.de (/etc/apache2/sites-enabled/dennisbuehler.conf:1)
         port 80 namevhost dennisbuehler.de (/etc/apache2/sites-enabled/dennisbuehler.conf:1)
         port 80 namevhost cloud.dennisbuehler.de (/etc/apache2/sites-enabled/nextcloud.conf:1)
/etc/apache2/sites-available/dennisbuehler.conf
<VirtualHost *:80>
        DocumentRoot /var/www/dennisbuehler.de/
        <Directory /var/www/dennisbuehler.de/>
                Require all granted
                AllowOverride None
     </Directory>
</VirtualHost>
/etc/apache2/sites-available/nextcloud.conf
<VirtualHost *:80>
                Require all granted
                AllowOverride All
                          Dav off
                        </IfModule>
        </Directory>
</VirtualHost>
Greetings
Which version of Certbot are you using?
Usually you would have been presented with a questionnaire when opening a thread in the #help section. Maybe it didn't show up, or maybe you deleted it for some weird reason. But let's get it back anyway:
Hi @Osiris ,
thanks for answering.
Domain:
dennisbuehler.de
Trying to run:
certbot --apache
Produced this output:
1: dennisbuehler.de
2: cloud.dennisbuehler.de
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/dennisbuehler.de.conf)
What would you like to do?
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/nextcloud-le-ssl.conf
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
 - We were unable to set up enhancement redirect for your server,
   however, we successfully installed your certificate.
   /etc/letsencrypt/live/dennisbuehler.de/fullchain.pem
   /etc/letsencrypt/live/dennisbuehler.de/privkey.pem
   Your cert will expire on 2023-06-18. To obtain a new or tweaked
   with the "certonly" option. To non-interactively renew *all* of
My webserver is;
Server version: Apache/2.4.41 (Ubuntu)
Server built:   2023-03-08T17:32:54
Root Login:
yes / ssh
Control Panel:
No
Certbot Client:
certbot 0.40.0
That could do with an update.
What shows?:
certbot certificates
shows
Found the following certs:
  Certificate Name: cloud.dennisbuehler.de
    Domains: dennisbuehler.de cloud.dennisbuehler.de www.dennisbuehler.de
    Expiry Date: 2023-06-10 16:47:55+00:00 (VALID: 79 days)
    Certificate Path: /etc/letsencrypt/live/cloud.dennisbuehler.de/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/cloud.dennisbuehler.de/privkey.pem
  Certificate Name: dennisbuehler.de
    Expiry Date: 2023-06-18 17:35:12+00:00 (VALID: 87 days)
    Certificate Path: /etc/letsencrypt/live/dennisbuehler.de/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/dennisbuehler.de/privkey.pem
The second cert seems useless; As both of those names are already included in the first cert.
Also, this list lacks the "www":
Which might be why you ended up with that second cert...
