Bonjour, je souhaite générer un certificat SSL avec cette commande et j’obtiens une erreur que je n’obtenais pas avant. Possible de m’aider ? Voilà :
root@monvps:~/letsencrypt# ./letsencrypt-auto --server https://acme-v01.api.letsencrypt.org/directory certonly
Bootstrapping dependencies for Debian-based OSes… (you can skip this with --no-bootstrap)
Get:1 http://security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
Hit:2 http://nova.clouds.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://nova.clouds.archive.ubuntu.com/ubuntu bionic-updates InRelease
Get:4 http://nova.clouds.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
Fetched 163 kB in 1s (224 kB/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
augeas-lenses is already the newest version (1.10.1-2).
ca-certificates is already the newest version (20180409).
libaugeas0 is already the newest version (1.10.1-2).
libffi-dev is already the newest version (3.2.1-8).
python is already the newest version (2.7.15~rc1-1).
python-dev is already the newest version (2.7.15~rc1-1).
python-virtualenv is already the newest version (15.1.0+ds-1.1).
gcc is already the newest version (4:7.3.0-3ubuntu2.1).
libssl-dev is already the newest version (1.1.0g-2ubuntu4.3).
openssl is already the newest version (1.1.0g-2ubuntu4.3).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Creating virtual environment…
Installing Python packages…
Command “/opt/eff.org/certbot/venv/bin/python2.7 -u -c “import setuptools, tokenize;file=’/tmp/pip-cBRGcn-build/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-_oZaDU-record/install-record.txt --single-version-externally-managed --compile --install-headers /opt/eff.org/certbot/venv/include/site/python2.7/wheel” failed with error code 1 in /tmp/pip-cBRGcn-build/
File “/tmp/tmp.DRREEk5vx3/pipstrap.py”, line 177, in <module>
exit(main())
File “/tmp/tmp.DRREEk5vx3/pipstrap.py”, line 164, in main
shell=True)
File “/usr/lib/python2.7/subprocess.py”, line 223, in check_output
raise CalledProcessError(retcode, cmd, output=output)
subprocess.CalledProcessError: Command ‘pip install --no-index --no-deps -U --no-cache-dir /tmp/pipstrap-TbObV3/pip-9.0.1.tar.gz /tmp/pipstrap-TbObV3/setuptools-29.0.1.tar.gz /tmp/pipstrap-TbObV3/wheel-0.29.0.tar.gz’ returned non-zero exit status 1
Merci !
