My domain is:gate0.ddns.net
I ran this command:sudo certbot --apache
blank to select all options shown (Enter ‘c’ to cancel): 1
Attempting to parse the version 0.37.1 renewal configuration file found at /etc/letsencrypt/renewal/gate0.ddns.net.conf with version 0.31.0 of Certbot. This might not work.
http-01 challenge for gate0.ddns.net
Waiting for verification…
Failed authorization procedure. gate0.ddns.net (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://gate0.ddns.net/.well-known/acme-challenge/uV7zqKcyc09je2jZP14flDH9JhzBRLtYExRnw6R-JIE [84.183.211.31]: “\n<!-- Pi-hole: A black hole for Internet advertisements\n* © 2017 Pi-hole, LLC (https://pi-hole.net)\n* Network”
Domain: gate0.ddns.net
Detail: Invalid response from
(https://pi-hole.net)\n* Network”To fix these errors, please make sure that your domain name was
My web server is (include version):Apache
The operating system my web server runs on is (include version):Raspberry PI 4b
or certbot-auto --version
if you’re using Certbot):certbot 0.31.0
