Problem with renewal of SSL certificate; cannot access site & webmail
My domain is: teorgemichael.com
I ran this command: Michel Beckers
It produced this output: Invalid response from https://acme-v01.api.letsencrypt.org/acme/authz/LAS4TxTF5Bg8mbGj8FKtHB2ZneiKc87TK1SAlg18wSs.
Details:
Type: urn:acme:error:connection
Status: 400
Detail: Fetching http://teorgemichael.com/.well-known/acme-challenge/HqLI3218ldot_M_VEmrPxM1-e4knFn-UWSxsAnotZB8: Timeout during connect (likely firewall problem)
The operating system my web server runs on is (include version): Apache/Ngix with Php 5.6.39 & Centos
My hosting provider, if applicable, is: https://www.protagonist.nl
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Onyx 17.0.17
Both port appreared to be not accessible for users in U.S. (status showed filtered). Since it’s not accessible in U.S, it’s likely some part of LE validation server can’t access your site too, which make the renewal failed.
Could you please check your port configuration? (Firewall settings?) And see if the IP resolved is correct?
Thank you
Hi @bapo
your site is completely invisible, same here (Berlin). But I see timeouts after 10 seconds, so your site doesn't answer.
It turned out that the VPS network on which my site is hosted had a malfunction …;(
It’s working now; it had nothing to do with SSL …
Thanx anyway!
Michel Beckers
----- Oorspronkelijk bericht -----
Very unique command and parameter... LOL
