Problem with renew cert
Hi, i have renew my certificate, but is not working.
My domain is: home.francescob.it
Hi @Aiace88
you have created one certificate - https://check-your-website.server-daten.de/?q=home.francescob.it#ct-logs
Let's Encrypt Authority X3 2019-08-05 2019-11-03 home.francescob.it - 1 entries
But your domain is invisible:
http://home.francescob.it/
185.119.228.37 -2 1.143 V
ConnectFailure - Unable to connect to the remote server No connection could be made because the target machine actively refused it 185.119.228.37:80
https://home.francescob.it/
185.119.228.37 -14 10.030 T
Timeout - The operation has timed out
http://home.francescob.it/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
185.119.228.37 -2 1.190 V
So first some informations about your configuration are required:
hi,@JuergenAuer , thanks for the help.
my domain is registered on aruba.
I made a cname record that associates home.francescob.it with my public ip.
every 90 days I did the procedure to update the validity from the hassio plugin (home assistant).
for the occasion I open the door 80 from the outside.
But that sounds good / excellent / should work.
What's now the problem?
if I try to use the services from the outside they don’t work, and from chrome identifies that the certificate has expired.2019-08-16%2021_40_40-Certificato
That's not a Letsencrypt certificate.
Is there an anti-virus-software that changes the certificate? So it's a man in the middle?
Or is it a self signed certificate, so the installation is incomplete?
It's impossible to check that if the port 443 is blocked.
