Problem with R3 expired
@TuXFire
Something has gone terribly wrong:
openssl s_client -connect tuxfire.ddns.net:443 -servername tuxfire.ddns.net
CONNECTED(00000005)
depth=1 C = US, O = Let's Encrypt, CN = R3
verify error:num=20:unable to get local issuer certificate
Certificate chain
 0 s:CN = tuxfire.ddns.net
   i:O = Digital Signature Trust Co., CN = DST Root CA X3
That path hasn't been provided since May 2021.
I suspect that your renewal process, or web service, may have hard-coded chain information in it.
[hard-coding anything of this nature is destined for failure]
Let's have a look at the web servers' HTTPS vhost config for the FQDNs having this problem.
So what should I do exactly?
locate emby | grep ssl
/opt/emby-server/etc/ssl
/opt/emby-server/etc/ssl/certs
/opt/emby-server/etc/ssl/certs/ca-certificates.crt
/opt/emby-server/lib/libssl.so
/opt/emby-server/lib/libssl.so.1.1
/var/lib/emby/ssl
/var/lib/emby/ssl/cert_54522e99effc77b8a5bc7ed2e196033b.pfx
/var/lib/emby/ssl/cert_8c4736fa62700595c6e767fc7588ce1c.pfx
/var/lib/emby/ssl/cert_9c31b7884ea5475c8687970fc5996297.pfx
/var/lib/emby/ssl/cert_af27e90a8b0c648430c4ca720bcb60cf.pfx
/var/lib/emby/ssl/emby.pfx
This seems up-to-date
This might not be:
Either look for an update/verify it is up-to-date OR maybe you can upload this file and we can check on how to manually alter it.
ca-certificates.crt.txt (196.9 KB)
That was quick!
Did you even look for an update?
How can I do that?
I did the command:
update-ca-certificates
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
Updating Mono key store
/etc/ca-certificates/update.d/mono-keystore: 10: /usr/bin/cert-sync: not found
Done
done.
It seems up-to-date:
## Certificate data from Mozilla as of: Tue May 25 03:12:05 2021 GMT
ISRG Root X1
-----BEGIN CERTIFICATE-----
So if it's up to date what could be the cause of the problem?
I know less than you do about emby (if that is what is serving the web content...)
Please show:
sudo netstat -pant | grep -Ei 'nginx|apache|httpd|:80|:443'
What is Kestrel?
curl -Iki https://tuxfire.ddns.net
HTTP/2 302
date: Mon, 04 Oct 2021 10:28:58 GMT
server: Kestrel
tcp 0 0 0.0.0.0:8096 0.0.0.0:* LISTEN 93725/EmbyServer
tcp 0 0 192.168.1.100:8096 192.168.1.10:47044 ESTABLISHED 93725/EmbyServer
tcp 0 0 192.168.1.100:8096 192.168.1.10:47030 ESTABLISHED 93725/EmbyServer
tcp 0 0 192.168.1.100:8096 192.168.1.10:46272 ESTABLISHED 93725/EmbyServer
By default Emby uses port 8096 for http and port 8920 for https
netstat -pant | grep -Ei 'nginx|apache|httpd|:8920|:443'
tcp 0 0 0.0.0.0:8920 0.0.0.0:* LISTEN 93725/EmbyServer
tcp 0 0 192.168.1.100:8920 37.165.7.84:25754 TIME_WAIT -
tcp 0 0 192.168.1.100:8920 192.241.198.231:48090 SYN_RECV -
tcp 0 0 192.168.1.100:8920 37.165.7.84:25757 ESTABLISHED 93725/EmbyServer
I don't know. Absolutly no idea
Well that makes two of us.
I know where the problem is: Kestrel/EmbyServer
But I have no further information for you on how to proceed.
locate Kestrel
/opt/dotnet/shared/Microsoft.AspNetCore.App/3.1.0/Microsoft.AspNetCore.Server.Kestrel.Core.dll
/opt/dotnet/shared/Microsoft.AspNetCore.App/3.1.0/Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll
/opt/dotnet/shared/Microsoft.AspNetCore.App/3.1.0/Microsoft.AspNetCore.Server.Kestrel.dll
/opt/emby-server/system/Microsoft.AspNetCore.Server.Kestrel.Core.dll
/opt/emby-server/system/Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.dll
/opt/emby-server/system/Microsoft.AspNetCore.Server.Kestrel.dll
kestrel is the web server it seems
Yes; as shown by the signature:
HTTP/2 302
date: Mon, 04 Oct 2021 11:01:12 GMT
server: Kestrel
What infos do you need to help me?
@TuXFire
I can't help you any further.
This is not an LE problem.
You need to find some support with Kestrel.
Their configuration files need to be checked/updated.
What exactly do I need to search in the config files ?
@tux
There will likely be some lines with either "cert" or "ssl" in them.
Or "pfx".
