Problem with mimeMap for "."
Solved .
Renewal broke with an IIS error. I isolated it to
  <mimeMap fileExtension="." mimeType="text/json" />
I replaced it in the letsencrypt prototype directory with
  <mimeMap fileExtension="" mimeType="application/octet-stream" />
Hi @BobFrankston
happy to read that you found a solution.
The standard setting is something like
<configuration>
    <system.webServer>
        <staticContent>
            <mimeMap fileExtension="." mimeType="text/plain" />
        </staticContent>
    </system.webServer>
</configuration>
perhaps only in the /.well-known/acme-challenge - directory.
That’s what I thought (though I don’t know why the template said json – but it shouldn’t matter). But the “.” stopped working and I had to use “”. Still don’t know why. Till the next failure…
