I have problem with getting ssl-certificate for server name olympmo.ru
The domain is accessable from internet by 80 and 443 (I have manually configured certificate for now)
On the same host I have also another nginx virtual host (server name) reg.olympmo.ru - and there no problem with certbot, it works.
Could you please check ip address for olympmo.ru in your DNS? It must be: 84.201.188.125. Because I'm not found the requests from certbot log in nginx log.
My domain is: olympmo.ru
I ran this command: sudo certbot --nginx
Requesting a certificate for olympmo.ru
Domain: olympmo.ru
Detail: 2a03:6f00:6:1::57f9:26fd: Invalid response from https://olympmo.ru/.well-known/acme-challenge/mqvfgArB-XS7XewZLtNaJl8YkcJw2xYbOd7PUg0Ii2g: 404
My web server is (include version): nginx 1.18.0
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: yandex.cloud
or certbot-auto --version
if you're using Certbot): certbot 1.29.0
