Hello everyone, i need a support
My domain is: elbrus-climbing.com, elbrus.vip
I will try to create certificate, but i see error in log file /home/bitrix/dehydrated_update.log: Error-creating-new-authz-Policy-forbids-issuing-for-name
This is misleading - both domains are actually fine to use with Let's Encrypt.
I would check a couple of things:
Rate Limit | Current Status | Domain |
50 Certificates per Registered Domain per week | OK (5 / 50 this week.) | elbrus-climbing.com |
5 Duplicate Certificates per week | Limit exceeded. Next issuable at 2018-12-13T14:09:02.000Z | elbrus-climbing.com |
Summary generated at Let's Debug Toolkit . |
full dehydrated_update.log:
I will try to create from bitrixvm. He is got automatic certificate release. I just add domain, DNS, email
Here is the key line:
Processing ns1.yandex.ru with alternative names: ns2.yandex.ru
Your error message about "policy forbids issuing for name" refers to yandex.ru
, which Let's Encrypt refuses to issue certificates for, because it is a high-risk/valuable domain.
Your server is requesting certificates for ns1.yandex.ru
and ns2.yandex.ru
... and I guess you do not really control these domains. You should remove them from dehydrated's configuration.
A record for elbrus.vip 146.158.12.240 Why he is asking DNS yandex servers?
Please show this file:
# INFO: Using main config file /home/bitrix/dehydrated/config
There are only 6 lines used in all that and none can explain why this is happening:
Are you on a “shared” system…?
Is there any other dehydrated file (or included file) that can explain it?
It might be in domains.txt
# File containing the list of domains to request certificates for (default: $BASEDIR/domains.txt)
#DOMAINS_TXT="${BASEDIR}/domains.txt"
Even though it’s commented, I suspect it’s the default place to stick your domains.
Or there is the nuclear option:
grep -Ri yandex /home/bitrix/dehydrated
Yes, in domains.txt. Is that a problem?
/home/bitrix/dehydrated/domains/elbruscliming.com.txt:ns1.yandex.ru ns2.yandex.ru
/home/bitrix/dehydrated/domains.txt:ns1.yandex.ru ns2.yandex.ru
Read https://github.com/lukas2511/dehydrated/blob/master/docs/domains_txt.md
By including those lines, you are asking Dehydrated to create certificates for ns1.yandex.ru
and ns2.yandex.ru
Remove those lines, and those domains will no longer be involved.
Thank you so much.
But now i see a new problem. I will try to create certificate for elbrus.vip
As I mentioned in my very first response, you’re currently rate limited from creating too many duplicate certificates.
You won’t be able to make one for your .com
domain for around 2 more days.
If you saved your existing certificates, you should just use them.
