Problem With Certbot
My domain is: csgo-italia.it
I ran this command: certbot --apache
It produced this output: Which names would you like to activate HTTPS for?
1: csgo-italia.it
2: www.csgo-italia.it
3: novagamer.it
4: www.novagamer.it
blank to select all options shown (Enter ‘c’ to cancel):2
tls-sni-01 challenge for www.csgo-italia.it
Waiting for verification…
Failed authorization procedure. www.csgo-italia.it (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Error getting validation data
    Domain: www.csgo-italia.it
    Type: connection
    Detail: Error getting validation data
My web server is (include version): centos 7
The operating system my web server runs on is (include version): centos 7
My hosting provider, if applicable, is: OVH
Hi @Giuseppe98PG,
When I try to connect to the IP resolved for www.csgo-italia.it on port 443 the connection fails with symptoms usually indicative of a firewall or middle box closing the connection.
Are you aware of anything that might be blocking connections to your server on port 443? That port will need to be accessible for the TLS-SNI-01 challenge (and for HTTPS once you have the certificate!)
Iptables could be a problem?
Yes, certainly possible. Do you have a DROP that might be occurring for this traffic?
yes man. I could make a iptable rule. I do it now.
I get this now
1: csgo-italia.it
3: novagamer.it
4: www.novagamer.it
Could not reverse map the HTTPS VirtualHost to the original
  • Unable to install the certificate
  • Congratulations! Your certificate and chain have been saved at
    /etc/letsencrypt/live/www.csgo-italia.it/fullchain.pem. Your cert
    will expire on 2017-11-30. To obtain a new or tweaked version of
    this certificate in the future, simply run certbot again with the
    "certonly" option. To non-interactively renew all of your
    certificates, run “certbot renew”
why unable to install the certificate?
This means that your certificate was issued and saved in a file (at the location mentioned). However, Certbot wasn’t able to understand your Apache configuration file in order to edit that file and tell Apache to use the certificate.
I don’t know exactly what problem Certbot had in understanding the Apache configuration, but in any case you don’t need to get a new certificate now (the certificate already exists on your system). Maybe you could look at the Apache configuration and see if there is something unusual about it.
One example that caused problems in the past is that Certbot expects that each virtual host will be defined by an individual, separate file. Apache allows you to define multiple virtual hosts within a single file, although this practice is apparently discouraged by more recent documentation. Earlier versions of Certbot could not correctly understand files that define more than one virtual host.
It would be possible to use certbot install to try this process again (maybe after changing the Apache configuration to make it clear to Certbot which file needs to be edited). Alternatively, it would be possible to install the certificate by manually editing Apache configuration files.
