That's not true:
server ~ # certbot certificates
Certificate Name: le-test-01.example.com
Serial Number: ...
Domains: le-test-01.example.com
Expiry Date: 2021-01-04 09:35:25+00:00 (INVALID: TEST_CERT)
Certificate Path: /etc/letsencrypt/live/le-test-01.example.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/le-test-01.example.com/privkey.pem
server ~ # certbot certonly -a apache --cert-name le-test-01.example.com -d le-test-01.example.com
Unable to read ssl_module file; not disabling session tickets.
Plugins selected: Authenticator apache (1.8.0.dev0), Installer None (None)
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/le-test-01.example.com.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the cert (may be subject to CA rate limits)
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
The output is different when adding a domain, but it still asks you what to do:
server ~ # certbot certonly -a apache --cert-name le-test-01.example.com -d le-test-01.example.com -d le-test-02.example.com
You are updating certificate le-test-01.example.com to include new
domain(s):
+ le-test-02.example.com
You are also removing previously included domain(s):
(None)
Did you intend to make this change?
(U)pdate cert/(C)ancel:
So I don't really understand your fascination with --keep-until-expiring.. Or I'm really missing something.. (But I don't think I do, as the examples above clearly state.)
We all are at some point. I'm just wondering why the apache authenticator failed for you.
If you had port 80 open then I wonder if your apache has different locations for things. You're not using Bitnami are you?
