That specifies the webroot, but doesn't select the webroot
authenticator.
Sorry for stepping in. I didn't want it to go unnoticed. You saw it though.
authenticator.
sorry I confound webroot and webroot-path options.
As I wasn't careful, I use certonly option. How to install certificate, Is that --installer option with webroot?
Just a little question more, why the apache option didn't work?
Thanks
If the webroot authenticator worked and the apache authenticator didn't, my guess would be either that certbot couldn't correctly process your apache configuration or that something in your apache installation itself is non-standard. You can specify certain things about your apache configuration to certbot using some options. See the apache:
section in the certbot command-line options for more information.
There is no webroot installer. You'll probably have to manually install the certificate by modifying your apache configuration to point to the files in live
then add a --deploy-hook
that will reload apache after each successful renewal.
Something like:
certbot certonly --webroot -w /var/www/html/ --deploy-hook "apachectl -k graceful"
You can always split authenticator and installer, see
Combining plugins.
https://certbot.eff.org/docs/using.html#combining-plugins
certbot run -a webroot -i apache -w /var/www/html -d example.com
Hello,
Sorry for late reply.
After installing the certificate, I cannot connect. So I had a doubt about my router setup.
To be sure, I installed a self signated certificate. Then that works with a warning message because the certificate authority is unknown (normal).
I create a new VM, Debian buster, install apache, create a virtualhost, install certbot, and I have the same problem with certbot --apache.
root@dolidelices:~# certbot --apache
Enter email address (used for urgent renewal and security notices)
(Enter 'c' to cancel): benoit@xxxx.com
agree in order to register with the ACME server. Do you agree?
(Y)es/(N)o: y
Would you be willing, once your first certificate is successfully issued, to
share your email address with the Electronic Frontier Foundation, a founding
partner of the Let's Encrypt project and the non-profit organization that
develops Certbot? We'd like to send you email about our work encrypting the web,
EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: y
Account registered.
1: dolidelice.zelec.homelinux.net
Requesting a certificate for dolidelice.zelec.homelinux.net
http-01 challenge for dolidelice.zelec.homelinux.net
Enabled Apache rewrite module
Challenge failed for domain dolidelice.zelec.homelinux.net
Domain: dolidelice.zelec.homelinux.net
Detail: Invalid response from
http://dolidelice.zelec.homelinux.net/.well-known/acme-challenge/aMxGEWf8RH7PwJDv6L5VuaGlmW3PkSDENDVXkpbQtMI
[92.188.16.194]: "\n\n404 Not
Found\n\n
I tried with webroot
root@dolidelices:~# certbot --webroot -w /var/www/html/
With the webroot plugin, you probably want to use the "certonly" command, eg:
(Alternatively, add a --installer flag. See https://eff.org/letsencrypt-plugins
and "--help plugins" for more information.)
root@dolidelices:~# certbot --webroot certonly -w /var/www/html/
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c'
to cancel): dolidelice.zelec.homelinux.net
Using the webroot path /var/www/html for all unmatched domains.
Subscribe to the EFF mailing list (email: benoit@z-elec.com).
We were unable to subscribe you the EFF mailing list because your e-mail address appears to be invalid. You can try again later by visiting https://act.eff.org.
So I wanted to install:
root@dolidelices:~# certbot run -a webroot -i apache -w /var/www/html -d dolidelice.zelec.homelinux.net
Plugins selected: Authenticator webroot, Installer apache
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/dolidelice.zelec.homelinux.net.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/dolidelice.zelec.homelinux.net.conf
Redirecting vhost in /etc/apache2/conf-enabled/dolibarr.conf to ssl vhost in /etc/apache2/sites-enabled/dolidelice.zelec.homelinux.net.conf
Congratulations! You have successfully enabled
https://dolidelice.zelec.homelinux.net
Now my /etc/apache2/sites-enable/dolidelice.zelec.homelinux.net.conf is:
ServerAdmin benoit@z-elec.com DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
ServerName dolidelice.zelec.homelinux.net
SSLCertificateFile /etc/letsencrypt/live/dolidelice.zelec.homelinux.net/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/dolidelice.zelec.homelinux.net/privkey.pem
Everything seems to be correct but when I try to connect I have ERR_SSL_PROTOCOL_ERROR.
Thanks for help
As @JuergenAuer mentioned earlier a couple of times...
you don't have VirtualHosts in your configuration.
Start by reading here:
Sorry, I created the vhost, but with the port 443.
I modify that, to have dolidelice.zelec.homelinux.conf:
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
# modules, e.g.
then certbot again
root@dolidelices:/etc/apache2/sites-available# certbot --apache
Renewing an existing certificate for dolidelice.zelec.homelinux.net
Created an SSL vhost at /etc/apache2/conf-available/dolibarr-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/conf-available/dolibarr-le-ssl.conf
Enabling available site: /etc/apache2/conf-available/dolibarr-le-ssl.conf
Enhancement redirect was already set.
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains:
but I can't connect, error ssl protocol.
I see no VirtualHost
block or ServerName
directive. Did you take a look at the documentation via the link that I provided? You seem to be missing many things.
I read the documentation, but I made a mistake when copy/paste
here the complete file
# modules, e.g.
Where are the <VirtualHost>
and </VirtualHost>
lines?
Blockquote
Blockquote
My friend, I'm meaning where are the two lines themselves that actually have VirtualHost
literally written in them?
For example:
<VirtualHost *:80>
DocumentRoot "/www/example1"
# Other directives here
</VirtualHost>
they appear when I type my text between <> but disapears when I publy it
Ah...
Edit your outputs and add this line above:
```text
and this line below:
Those will format your outputs correctly. They must be on separate lines from your output.
thanks for the information. I made a printscreen of the file
<VirtualHost dolidelice.zelec.homelinux.net:80>
# modules, e.g.
</VirtualHost>
Thanks for that. Please try what I mentioned though, just so that I can be sure our formatter is working correctly.
That's better like that
