I was trying to create the certificate (from my AWS) by doing following:
form my opt/letsencrypt I run
.letsencrypt-auto certonly --standalone --debug
When I was prompt to enter the domain name i messed up my IP entries somehow and had to exit so I didnt know how to get back to that prompt so I run again command below.
and I was prompt to enter domain name which I did and I received this:
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c’
to cancel): xx.xxx.xxx.xxx.xip.io
http-01 challenge for xx.xxx.xxx.xxx.xip.io
Waiting for verification…
Exiting abnormally:
** File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in **
** sys.exit(main())**
** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1240, in main**
** return config.func(config, plugins)**
** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 1120, in certonly**
_** lineage = get_and_save_cert(le_client, config, domains, certname, lineage)**
_** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/main.py”, line 118, in get_and_save_cert**
** lineage = le_client.obtain_and_enroll_certificate(domains, certname)**
** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py”, line 357, in obtain_and_enroll_certificate**
** certr, chain, key, _ = self.obtain_certificate(domains)**
** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py”, line 336, in obtain_certificate**
** domains, csr, authzr=authzr)**
** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/client.py”, line 278, in obtain_certificate_from_csr**
** authzr)**
** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py”, line 314, in request_issuance**
** headers={‘Accept’: content_type})**
** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py”, line 709, in post**
_** return self.post_once(*args, kwargs)
_** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py”, line 722, in post_once**
_** return self.check_response(response, content_type=content_type)**
_** File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/acme/client.py”, line 583, in check_response**
** raise messages.Error.from_json(jobj)**
Error: urn:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new cert :: too many certificates already issued for: xip.io: see https://letsencrypt.org/docs/rate-limits/
Can anyone suggest/help how to get this certificate at this point please.
