Problem trying to renew my certificate
So, I am very new to that. I have an application that runs inside a VPN, on a Linux VM of my client, to which I have access. But to use it externally, I am using Apache.
This is my ports.conf file:
Listen 80
<IfModule ssl_module>
   Listen 443
</IfModule>
<IfModule mod_gnutls.c>
   Listen 443
</IfModule>
My sites-available/domain.conf is something like that:
<VirtualHost *:80>
        ServerAdmin my_server_admin
        ServerName my_domain_url
 <Proxy *>
                Order allow,deny
                Allow from all
        </Proxy>
        ProxyPass / http://localhost:8081/my_domain/
        ProxyPassReverse / http://localhost:8081/my_domain/
        <Location /cdaweb>
                ProxyPass http://localhost:8081/my_domain
                ProxyPassReverse http://localhost:8081/my_domain
        </Location>
</VirtualHost>
And my default-ssl.conf:
<IfModule mod_ssl.c>
        <VirtualHost _default_:443>
                DocumentRoot /var/www/html
                SSLEngine on
                SSLCertificateFile      /etc/ssl/certs/ssl-cert-snakeoil.pem
                SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
  <FilesMatch "\.(cgi|shtml|phtml|php)$">
                                SSLOptions +StdEnvVars
                </FilesMatch>
                <Directory /usr/lib/cgi-bin>
                </Directory>
      </VirtualHost>
</IfModule>
So, when I try to run sudo certbot renew I always get this error:
Challenge failed for domain my_domain
http-01 challenge for my_domain
  Domain: my_domain
  Type:   connection
  Detail: my_domain_ip: Fetching http://my_domain/.well-known/acme-challenge/DyPyF5DK2dppQHnATloaXtmpoYEc7_NWH868MielQLs: Timeout during connect (likely firewall problem)
Failed to renew certificate my_domain with error: Some challenges have failed.
I have also checked sudo iptables -L -n | grep -E ":(443|80)" and it shows:
I have tried to activate firewall and allow ports 80 and 443. But the renew command still doesn't work. I have seen somewhere this command: apachectl -t -D DUMP_VHOSTS and when I run it I get:
AH00526: Syntax error on line 47 of /etc/apache2/sites-enabled/m_domain-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/my_domain/fullchain.pem' does not exist or is empty
Action '-t -D DUMP_VHOSTS' failed.
I don't know how I should proceed to fix that. Please let me know where I am being dumb and how I could fix that quickly.
Try that with sudo:
sudo apachectl -t -D DUMP_VHOSTS
That output only shows :8080 which is NOT :80
Thanks for the answer!
I tried sudo apachectl -t -D DUMP_VHOSTS and got:
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443                  is a NameVirtualHost
         default server my_domain (/etc/apache2/sites-enabled/my_domain-le-ssl.conf:2)
         port 443 namevhost my_domain (/my_domainetc/apache2/sites-enabled/my_domain-le-ssl.conf:2)
         port 443 namevhost my_domain (/etc/apache2/sites-enabled/default-ssl.conf:2)
*:80                   is a NameVirtualHost
         default server my_domain (/etc/apache2/sites-enabled/my_domain.conf:1)
         port 80 namevhost my_domain (/etc/apache2/sites-enabled/my_domain.conf:1)
You were right. I realized port 80 was not open. It was just 8080. So I asked for my client's infra to open it, and it worked. Thank you!
