Hello , im new doing server shit and i tryied but got really confused , thanks for the help
My domain is: amp.kingdomsv.net
I ran this command: sudo ampinstmgr setupnginx amp.kingdomsv.net 80
It produced this output: servidor1@x:~$ sudo ampinstmgr setupnginx amp.kingdomsv.net 8080
[Info] AMP Instance Manager v2.2.0.2 built 26/07/2021 12:54
[Info] Release spec: Release - built by CUBECODERS/buildbot on CCL-DEV
http-01 challenge for amp.kingdomsv.net
Challenge failed for domain amp.kingdomsv.net
Domain: amp.kingdomsv.net
Type: connection
Detail: Fetching
http://amp.kingdomsv.net/.well-known/acme-challenge/07InJfrelfggmG1l60q4SismRRui4SrZwIeL6lcsC48:
[Error] Certbot failed with code 1
My web server is (include version): i dont know :c
The operating system my web server runs on is (include version): ubuntu 20.04.2 LTS
My hosting provider, if applicable, is: i dont have , i buy a pc to work like a server
or certbot-auto --version
if you're using Certbot): dont know :c
