Problem to get a certificate for a non www domain
I can’t get a certificate for non-www domain, certbot is only getting for www domain.
The domain is:
jceos.com
certbot --apache -d jceos.com -d www.jceos.com
Failed authorization procedure. jceos.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://jceos.com/.well-known/acme-challenge/sHqdFd_QPKNqpXkTBJFhO2wqipYoAyD2UcPyGW3HMis: "<body style=“padding:0; margin:0;”><iframe src=“http://mcc.godaddy.com
Apache/2.4.29 (Ubuntu)
Ubuntu 18.04.1 LTS (Bionic Beaver)
The domain was registered in godaddy
My VPS is in locaweb
Yes, I can.
No, I’m not using it.
Hi @lipesmile
there are different ip addresses:
Your non-www has two addresses:
D:\temp>nslookup jceos.com.
Addresses: 184.168.221.39
191.252.201.58
But your www has only one.
D:\temp>nslookup www.jceos.com.
Address: 191.252.201.58
Aliases: www.jceos.com
So try to remove the non-www 184.168.221.39 address.
