Problem to create a ssl certificate for pterodactyl panel
I'm having problems making pterodactyl panels
mydomain; mysslab.top ,panel.mysslab.top is there anyone who can help me
Your screenshot shows that your panel is trying to get a certificate for panel.myss.my.id and not either of the .top domains you mentioned. I'd start by figuring out why your panel thinks it is called something different than your domain.
I'd start my confirming the IP matches your server:
And then open the firewall for HTTP access:
