Challenge failed for domain webmail.recomsa.com.pa
http-01 challenge for webmail.recomsa.com.pa
Domain: webmail.recomsa.com.pa
Type: dns
Detail: During secondary validation: DNS problem: query timed out
looking up A for webmail.recomsa.com.pa
apache 2.4
opensuse 15.1
IONOS
yes, I have root access
no
1.14.0
From the error it seems like a DNS resolve issue, but I've checked with several online DNS checkers and all resolve ok to my domain. I also noticed that there is "Planned Maitenance in Progress" with the status checker of your service, is it possible this is related to that?
pa to com.pa: No delegation NS records were detected in the parent zone (pa). This results in an NXDOMAIN response to a DS query (for DNSSEC), even if the parent servers are authoritative for the child.
com.pa to recomsa.com.pa: The following NS name(s) were found in the delegation NS RRset (i.e., in the com.pa zone), but not in the authoritative NS RRset: ns1.dopate.com
Which I'm not sure are your problem, but probably aren't helping anything. Are you sure your DNS servers (both ns1.dopate.com and ns2.dopate.com) are configured properly?
No, that's just that ACME v1 is going away, and not related to your issue.
mm ok, I'll check with my DNS provider then, I only have access to my registers through a cPanel interface, but from what you're describing the issue is in a higher DNS level
I checked with the DNS service I have and they inform me the problem reported from DNSViz might be that their network is not in the range of the VPS provider I use. I have a domain name registered in Panama that points to a VPS service from the IONOS hosting provider. Is this a limitation for requesting an SSL certificate from LetsEncrypt? It worked ok back in January 2021.
I'm not quite sure what that means. The message from Let's Encrypt is that the DNS servers aren't responding to their queries, and the report from DNSViz is that your DNS delegation isn't consistent (what com.pa says your NS servers are doesn't line up with what the recomsa.com.pa zone says your NS servers are. I don't think any of that is related to your VPS, but to your DNS servers. Are you running your own DNS server on your VPS?
There shouldn't be any such limitations, as long as your nameservers are configured correctly and are returning results to Let's Encrypt when its system queries them.
I'm kind of in a limbo here, I managed to successfully request a certificate in January but the request again in April failed. The DNS service in Panama insists it's not their fault, is it possible that LetsEncrypt included the secondary check recently and SSL certificates don't get issue if the DNS and the host provider are not in the same geographical regions?
The only possible issue "geographical regions" might have is if your dns server has some sort of firewall that blocks traffic based on geographical regions, or if your dns server is only routable from certain regions. Let's Encrypt validates that your systems are reachable from several vantage points around the world, and has done so for over a year. If your DNS server can't get traffic from Let's Encrypt's servers then you won't be able to get a Let's Encrypt certificate. (Similarly, if traffic from other CAs can't get to your servers, they won't be able to validate you either, and if users can't get to your DNS servers then your users won't be able to get to you.)
While I don't think it's related to the error you're getting, your AAAA record for webmail.recomsa.com.pa is a link-local fe80:: address, not a globally-routable address, so I don't think an HTTP challenge could work anyway, even if Let's Encrypt could get to your DNS servers.
@JuergenAuer@petercooperjr decided today to give it another go and it worked. Nothing changed with the DNS provider, and nothing on my part on the VPS. Don't really know what happened.
I think your dns provider has tested and changed some firewall rules.
That's a general problem. Most users use dns services, don't run their own (me too), but if the dns provider has some filters, that may be critical, because Letsencrypt doesn't use cached results.
Instead, the autoritative name servers are checked -> some traffic -> block.
