Problem renewing, used to work now stopped
#1
My domain is: www.fingerprintsoft.co
sudo /opt/certbot-auto -w /var/www/fingerprintsoft.co/html/ --apache certonly
/opt/certbot-auto renew
Failed authorization procedure. fingerprintsoft.co (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :
apache - httpd-2.2.15-69.el6.centos.x86_64
CentOS release 6.3 (Final)
Yes
No
#2
Could you post the full output from that command? There’s a lot more info that’s provided which we need to be able to help you. The bit you posted by itself is a very common error message with a great number of possi le causes.
#3
Hi @fuzails
I see, you tested your domain :wink:
If you want to use the webroot, then split it:
sudo /opt/certbot-auto -a webroot -w /var/www/fingerprintsoft.co/html/ -i apache certonly
-a - authenticator webroot
-i - installer apache
But if you use certonly, you don’t need an installer. So use
sudo /opt/certbot-auto -a webroot -w /var/www/fingerprintsoft.co/html/ certonly
#4
thanks, didnt have to use webroot before, jsut tried it with
/opt/certbot-auto -a webroot -w /var/www/fingerprintsoft.co/html/ certonly -d www.fingerprintsoft.co and it worked
Going to wait for rate limiting to finish and then attempt for all domains required.
#5
Then you should add both domain names:
-d fingerprintsoft.co -d www.fingerprintsoft.co
If the dns entry exists, both domain names should allow a correct https connection without a certificate error.
#6
http-01 challenge for fingerprintsoft.co
Waiting for verification…
Failed authorization procedure. fingerprintsoft.co (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://fingerprintsoft.co/.well-known/acme-challenge/jfhTFIS5aSBOyn0npbhWtVExMHkpfjvH6LkNu_LG5HA: "\n<?xml version=\"1.0\" encoding=\"utf-8\"?>\n<!DOCTYPE html PUBLIC “-//W3C//DTD XHTML 1.0 Strict//EN”\n “http://www.w3.org/TR/xhtml1/D
Domain: fingerprintsoft.co
Detail: Invalid response from
I initially used to renew with:
sudo /opt/certbot-auto --apache certonly
Only tried webroot today.
#7
Thanks that has worked beautifully, regards
#8
