Problem installing Let's Encrypt certificate on my wiki
Hello,
I have a mediawiki site with the lamp stack.
I'm having a problem trying to install SSL certificate through Let's Encrypt. My wiki is crashing and I can't load it.
My domain is twogpedia.com
I tried to install the SSL certificate of Let's Encrypt and now my wiki doesn't want load.
It produced this output when I type the URL on google: "This site can’t be reached."
My web server is (include version): Apache version 2.4.53
The operating system my web server runs on is (include version): Amazon Linux 2, version 5.10
My hosting provider, if applicable, is: AWS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.11.0
Your port 443 (https) is not open. If you are in an EC2 instance make sure your Security Group allows this port.
Oh, and welcome to the community @devsaur
Thank you! It's a pleasure is here :smiley:
And, then... How can I check if the port is open?
I used nmap but if you don't have that just try:
curl -I -m15 https://twogpedia.com
If it times out in 15 seconds then it probably isn't open.
The port is really closed. Do you have any idea how I can open it?
I'd just Google: open HTTPS in AWS
You seem to be using an EC2 instance. Go to your EC2 Dashboard in your AWS Console. In the left menu there will be a section for Security Group.
I did this and it is not working at all. Could it be some other problem?
Please show the output of:
netstat -pant | grep -i listen
Your site is now working using HTTP (port 80) but HTTPS (port 443) is still not working.
What was the certbot command you tried and what is the latest error message?
I am also interested in the info from the netstat command that Rudy showed.
