Hi I’m trying to install and use letsencrypt with cerbot in my domain just4goals.com with an apache and, tomcat server in a AWS EC2.
My problem is when I ran this command:
sudo certbot --apache
Detail: Invalid response from
http://just4goals.com/.well-known/acme-challenge/LgegFhsYi6eJoYjBkTdlJ_DNcViurlxxi3W7TbnMI-U
[18.219.199.31]: 503
Am i doing something wrong?, should I remove or add something?
Thanks!
