My domain is: bdigital.uncu.edu.ar
Hello all
I am using NPMPlus to manage my domains and certificates. I need to generate a wildcard certificate *.bdigital.uncu.edu.ar
The guys that manage te DNS provided me the info to configure the RFC2136 plugin at NPMPlus but I keep getting a SERVFAIL error
I can't determine if there is something wrong with the info I used to confiigure it or with the plugin itself
my certbot_log file contains the following:
2026-09-17 13:02:46,092:DEBUG:certbot._internal.main:certbot version: 5.8.0
2026-09-17 13:02:46,092:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/local/bin/certbot
2026-09-17 13:02:46,092:DEBUG:certbot._internal.main:Arguments: ['--config', '/etc/certbot.ini', '--server', 'https://acme-v02.api.letsencrypt.org/directory', '--cert-name', 'npm-108', '--domains', '*.bdigital.uncu.edu.ar', '--no-reuse-key', '--authenticator', 'dns-rfc2136', '--dns-rfc2136-credentials', '/tmp/certbot-credentials/credentials-108']
2026-09-17 13:02:46,093:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#dns-rfc2136,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2026-09-17 13:02:46,098:DEBUG:certbot._internal.log:Root logging level set at 30
2026-09-17 13:02:46,098:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-rfc2136 and installer None
2026-09-17 13:02:46,098:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * dns-rfc2136
Description: Obtain certificates using a DNS TXT record (if you are using BIND for DNS).
Interfaces: Authenticator, Plugin
Entry point: EntryPoint(name='dns-rfc2136', value='certbot_dns_rfc2136._internal.dns_rfc2136:Authenticator', group='certbot.plugins')
Initialized: <certbot_dns_rfc2136._internal.dns_rfc2136.Authenticator object at 0x7f4e207ac6e0>
Prep: True
2026-09-17 13:02:46,098:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot_dns_rfc2136._internal.dns_rfc2136.Authenticator object at 0x7f4e207ac6e0> and installer None
2026-09-17 13:02:46,098:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator dns-rfc2136, Installer None
2026-09-17 13:02:46,256:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/3712422276', new_authzr_uri=None, terms_of_service=None), 643fd0c99da2cd3ca1a82042eb6b77f4, Meta(creation_dt=datetime.datetime(2026, 9, 5, 15, 8, 51, tzinfo=datetime.timezone.utc), creation_host='bc-server-i9', register_to_eff=None))>
2026-09-17 13:02:46,257:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2026-09-17 13:02:46,257:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2026-09-17 13:02:46,745:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 961
2026-09-17 13:02:46,745:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 17 Sep 2026 16:02:46 GMT
Content-Length: 961
X-Frame-Options: DENY
"hLAN0B6u-sg": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"profiles": {
"classic": "https://letsencrypt.org/docs/profiles#classic",
"shortlived": "https://letsencrypt.org/docs/profiles#shortlived",
"tlsserver": "https://letsencrypt.org/docs/profiles#tlsserver"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.8-July-06-2026.pdf",
"renewalInfo": "https://acme-v02.api.letsencrypt.org/acme/renewal-info",
2026-09-17 13:02:46,746:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for *.bdigital.uncu.edu.ar
2026-09-17 13:02:46,749:DEBUG:acme.client:Requesting fresh nonce
2026-09-17 13:02:46,749:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2026-09-17 13:02:46,909:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2026-09-17 13:02:46,910:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Replay-Nonce: dll9i3XqJbJEdW8gzhZcZtgwgzqeWt_uH8RXaEcWHq5zoqSn1yk
2026-09-17 13:02:46,910:DEBUG:acme.client:Storing nonce: dll9i3XqJbJEdW8gzhZcZtgwgzqeWt_uH8RXaEcWHq5zoqSn1yk
2026-09-17 13:02:46,911:DEBUG:acme.client:JWS payload:
b'{\n "profile": "shortlived",\n "identifiers": [\n {\n "type": "dns",\n "value": "*.bdigital.uncu.edu.ar"\n }\n ]\n}'
2026-09-17 13:02:46,924:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzcxMjQyMjI3NiIsICJub25jZSI6ICJkbGw5aTNYcUpiSkVkVzhnemhaY1p0Z3dnenFlV3RfdUg4UlhhRWNXSHE1em9xU24xeWsiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
"signature": "aVZGjnJrrHk6jpDu3CMN6WZVBTEgq_G1rfrrseMmxYSllRWQdm_TeW4mCe-vI4xtLEXfgWFuhn3QvMqRN6yQCQOjUgpGJJnEgZvmsAH3uix96j6iBLW4YPwDtKkgk7i4MU96LgSOoGlv9QKccUZr6UfH1MhfvjrsMuzCGi85K9DnlqeFTj9cMY3ur-r4-ujtT-rh6OAkqGSGxZjmer-M8xzr2FVwuzWheOebmZ6BvONYKJ1f_O1aXeUzeZceZzuwW207qMUlj1MFR9-Jvpgz3S0BsOsoZCQnxRVqZBxKdyIb4jUUuGLGoAbZLs0_eD2yCNj1c8JdnIoV9j51SbSICk12wS0jgMzCpIBmn1gEz-uvbRaci6oQ3R0upnVrcdZcWfk8w0yiuvT9oLmf4ztuZGl_58HcgohA4UcMfOOIKkrJVVjM2t57DEhesieBU7wNTarwA6u6x8X0fGW5ngIu_2vk5m7OQcxpm8pKH564SHmkntZu95zcYIwkCykdPe58YOeSFb9aBH1HJh73NzY23wpLiPooSNAiVdE-L5224aNUs6iRPhBD7HPQ_OM9XXwT2fXdGWYLH_WaEOA6SY7yxfU0dWyphcKyoxUAhSSWnPletHuAizET96FAf3tTJJ5LpkBygDce9vtAz4vdSBipgz99Wdyl2debw4u2bc3JIBs",
"payload": "ewogICJwcm9maWxlIjogInNob3J0bGl2ZWQiLAogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogIiouYmRpZ2l0YWwudW5jdS5lZHUuYXIiCiAgICB9CiAgXQp9"
2026-09-17 13:02:47,183:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 383
2026-09-17 13:02:47,184:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Date: Thu, 17 Sep 2026 16:02:47 GMT
Content-Length: 383
Boulder-Requester: 3712422276
Location: https://acme-v02.api.letsencrypt.org/acme/order/3712422276/558547565916
Replay-Nonce: dwBChqYhtQPWKvO7ZuyYekzMD9WEv7DNBMoxO2jWh2q4eQNKiCc
"status": "pending",
"expires": "2026-09-17T17:02:47Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz/3712422276/781951240116"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/3712422276/558547565916",
2026-09-17 13:02:47,184:DEBUG:acme.client:Storing nonce: dwBChqYhtQPWKvO7ZuyYekzMD9WEv7DNBMoxO2jWh2q4eQNKiCc
2026-09-17 13:02:47,184:DEBUG:acme.client:JWS payload:
b''
2026-09-17 13:02:47,187:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz/3712422276/781951240116:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzcxMjQyMjI3NiIsICJub25jZSI6ICJkd0JDaHFZaHRRUFdLdk83WnV5WWVrek1EOVdFdjdETkJNb3hPMmpXaDJxNGVRTktpQ2MiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LzM3MTI0MjIyNzYvNzgxOTUxMjQwMTE2In0",
"signature": "Dma7I5hJkDD47j2AvPfvxqsQZ4nFfQEfQgqrarlfbnQdWIPW0BMr-dN0GgFlpSyx91-ibM3NAGWxCL4fnqKfAbO3y8kNZPmShP-yCxuRRTTybEC_0GOsMmsJceb4MGoKEY9FnwJdrVLLaUDylFIGO0k0iPNTxSFDel-JBIf03IZIPEfPJqi_G3_d_0VKTEmo8oNLLe5v0U101zpgCiMdAucIOyp8t_U_x-G_kYFDL7eivBTKQon82AU_vW0_fDcHIJAD2W4jrTP0n_QgBE0zmPbJ9m-Yt4Plb3dEp-Ye_XIPptmIg7414CKPm2TkfzJC-lMPXEh7WVlqNoo0WtHR_5Xb8o1j1bu1uL4xZhM7w-4a4Acx7pxzshSl6ZQp8-ymvL6yuEpqPknkZezZxYCgSr3Aek-OG0zE_-KsTKzDlIpwEIuiZHukWQYBfoiZRLt89LbE3EfH70DyIlEXLOFngjSzg7ekxTJ4DJ8TMlDf87pLE7aI_jMpRR1CmE5Vcv_CaPLIa8Uki4-TWx09kkvOZAKEM7fx600BU3yaFP2Jcz1nrhbB-x5M5SZJMcgTb-nOA76FPHkGdYPa0OTPVU8pvoOqL2TA9N3Pt4lRePZaMEgPv_TgUYPj425g_guyAwy-8nNEDOY87b6qUvcn44xTZuNUr-n7fkTKAFYJulL95-8",
"payload": ""
2026-09-17 13:02:47,351:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz/3712422276/781951240116 HTTP/1.1" 200 402
2026-09-17 13:02:47,351:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 402
Replay-Nonce: dll9i3XqLGOgl02z8zelYWJ_oE0qQ18uits4zWjNh48kGb31KpY
"identifier": {
"type": "dns",
"value": "bdigital.uncu.edu.ar"
"challenges": [
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall/3712422276/781951240116/oxpcMA",
"token": "LtHp6Fw1ITkg11znPP4dPH0yAgWKs5LcKMqg44VSDkw"
"wildcard": true
2026-09-17 13:02:47,352:DEBUG:acme.client:Storing nonce: dll9i3XqLGOgl02z8zelYWJ_oE0qQ18uits4zWjNh48kGb31KpY
2026-09-17 13:02:47,352:INFO:certbot._internal.auth_handler:Performing the following challenges:
2026-09-17 13:02:47,352:INFO:certbot._internal.auth_handler:dns-01 challenge for Identifier(typ=IdentifierType(dns), value='bdigital.uncu.edu.ar')
2026-09-17 13:02:47,365:DEBUG:certbot_dns_rfc2136._internal.dns_rfc2136:No authoritative SOA record found for _acme-challenge.bdigital.uncu.edu.ar
2026-09-17 13:02:47,381:DEBUG:certbot_dns_rfc2136._internal.dns_rfc2136:Received authoritative SOA response for bdigital.uncu.edu.ar
2026-09-17 13:02:47,393:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/usr/local/lib/python3.14/site-packages/certbot/_internal/auth_handler.py", line 84, in handle_authorizations
resps = self.auth.perform(achalls)
File "/usr/local/lib/python3.14/site-packages/certbot/plugins/dns_common.py", line 78, in perform
self._perform(domain, validation_domain_name, validation)
File "/usr/local/lib/python3.14/site-packages/certbot_dns_rfc2136/_internal/dns_rfc2136.py", line 85, in _perform
self._get_rfc2136_client().add_txt_record(validation_name, validation, self.ttl)
File "/usr/local/lib/python3.14/site-packages/certbot_dns_rfc2136/_internal/dns_rfc2136.py", line 152, in add_txt_record
raise errors.PluginError('Received response from server: {0}'
.format(dns.rcode.to_text(rcode)))
certbot.errors.PluginError: Received response from server: SERVFAIL
2026-09-17 13:02:47,393:DEBUG:certbot._internal.error_handler:Calling registered functions
2026-09-17 13:02:47,393:INFO:certbot._internal.auth_handler:Cleaning up challenges
2026-09-17 13:02:47,398:DEBUG:certbot_dns_rfc2136._internal.dns_rfc2136:No authoritative SOA record found for _acme-challenge.bdigital.uncu.edu.ar
2026-09-17 13:02:47,402:DEBUG:certbot_dns_rfc2136._internal.dns_rfc2136:Received authoritative SOA response for bdigital.uncu.edu.ar
2026-09-17 13:02:47,406:DEBUG:certbot_dns_rfc2136._internal.dns_rfc2136:Successfully deleted TXT record _acme-challenge.bdigital.uncu.edu.ar
2026-09-17 13:02:47,407:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/local/bin/certbot", line 6, in <module>
sys.exit(main())
File "/usr/local/lib/python3.14/site-packages/certbot/main.py", line 18, in main
File "/usr/local/lib/python3.14/site-packages/certbot/_internal/main.py", line 1889, in main
File "/usr/local/lib/python3.14/site-packages/certbot/_internal/main.py", line 1601, in certonly
lineage = _get_and_save_cert(le_client, config, sans, certname, lineage)
File "/usr/local/lib/python3.14/site-packages/certbot/_internal/main.py", line 143, in _get_and_save_cert
lineage = le_client.obtain_and_enroll_certificate(sans, certname)
File "/usr/local/lib/python3.14/site-packages/certbot/_internal/client.py", line 533, in obtain_and_enroll_certificate
cert, chain, key, _ = self.obtain_certificate(sans)
File "/usr/local/lib/python3.14/site-packages/certbot/_internal/client.py", line 434, in obtain_certificate
File "/usr/local/lib/python3.14/site-packages/certbot/_internal/client.py", line 512, in _get_order_and_authorizations
2026-09-17 13:02:47,409:ERROR:certbot._internal.log:Received response from server: SERVFAIL
