My domain is: taylortv.art
I ran this command: owi_sslupdater from overseerr installer
[taylortv.art] Authorizing...
[taylortv.art] Authorizing using http-01 validation (FileSystem)
Answer should now be browsable at http://taylortv.art/.well-known/acme-challenge/Ihc6pYCYsr4nZ0go0qQVn4he0aoyVEfaCJyN04Y7PEw
Preliminary validation failed because 'The requested name is valid, but no data of the requested type was found.'
[taylortv.art] Authorization result: invalid
[taylortv.art] {
"type": "urn:ietf:params:acme:error:dns",
"detail": "No valid IP addresses found for taylortv.art",
"status": 400
Create certificate failed: [taylortv.art] Validation failed
nginx: [error] OpenEvent("Global\ngx_reload_16016") failed (5: Access is denied)
PHP: STOP: The operation completed successfully.
PHP: START: The operation completed successfully.
NGINX: STOP: The operation completed successfully.
NGINX: START: The operation completed successfully.
Waiting for 0 seconds, press CTRL+C to quit ...
Nginx status : SERVICE_RUNNING
PHP status : SERVICE_RUNNING
########## Installation Completed ##########
My web server is (include version): nginx 1.18.0
The operating system my web server runs on is (include version): Windows 10 Pro v21H1
My hosting provider, if applicable, is: namecheap.com
I can login to a root shell on my machine (yes or no, or I don't know): i dont know
or certbot-auto --version
if you're using Certbot): N/A I think (installer auto-ran a lot of things)
