Hallo,
i have test the certificate https://www.ssllabs.com/ssltest/analyze.html?d=anzahcloud.de
now i get the message:
Prefix handling Not valid for “anzahcloud.de” CONFUSING
Can anyone say me how i can fix this please?
Hallo,
Your certificate should at least include www.anzahcloud.de
as alternative name, because many users still prefix everything with www
How did you issue that certificate with that “happy hacker fake CA”?
If www.anzahcraft.de and anzahcraft.de are the same server, you can use the command-line -d
flag to request a certificate for multiple names, eg:
./letsencrypt-auto auth -d anzahcraft.de -d www.anzahcraft.de
When being asked for the domains, just add it as another domain.
Put them into a single certificate to resolve the issue.
i try but i havent know how i do this
ok this command run fine
//EDIT
must i update the cert with the same command?
