Maybe I'll have to correct myself back to my original impression and statement. Thanks, @Osiris!
Maybe indeed. The first part of the OpenSSL output is just like when viewing the cert chain in a browser: it's showing which chain is being build. The second part is more interesting. For example, this is my OpenSSL output for the long chain:
CONNECTED(00000003)
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = lencr.org
verify return:1
Certificate chain
0 s:CN = lencr.org
2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
i:O = Digital Signature Trust Co., CN = DST Root CA X3
Notice that the chain send by the server is different (bottom part), but the top part, the chain actually build, is identical to the short chain above! (Besides the hostname of the site of course..) That's because my OpenSSL (1.1.1) will terminate the chain at ISRG Root X1, even with the long chain being send by the server. Just like most browsers.
Yes, for sure.
It's an express server, the files cert.pem and key.pem are copied from /etc/letsencrypt/live/explogroup.ca/cert.pem (and privkey.pem).
const https = require('https');
const privateKey = fs.readFileSync('key.pem', 'utf8');
const certificate = fs.readFileSync('cert.pem', 'utf8');
const credentials = {key: privateKey, cert: certificate};
const express = require('express');
const path = require('path');
const app = express();
app.use(express.static(path.join(__dirname, 'public')));
app.get('/*', function (req, res) {
res.sendFile(path.join(__dirname, 'public', 'index.html'));
app.listen(80)
const httpsServer = https.createServer(credentials, app);
httpsServer.listen(443);
The real domain is explogroup.ca
I have the certificates in the same folder than my express server. After renewing the certificates I delete the old ones and copy the new ones from /etc/letsencrypt/live/explogroup.ca
The fullchain.pem is the following :
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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So you're not using fullchain.pem
at all? Which is kinda weird, as your site is sending the short chain perfectly.
Oh sorry, I forgot to write that I'm currently trying to use fullchain.pem insteand of cert.pem
About what you wrote yesterday @Osiris , it seems that https://www.lencr.org is working for me, but not https://www.explogroup.ca. By "not working", I mean with Safari on my Macbook I have an issue "This connection is not Private"
Do you have an idea why ?
Thanks! So, your site is currently correctly sending the short chain as you requested to, and your certificate configuration is valid. Are you having some compatibility or validation problems that are still concerning you?
With Safari (version 14.1.2) on my Macbook Pro (macOS Bis Sur version 11.6) I still have the "This connection is not private" issue.
The trouble is that probably several of the visitors of the website will have the issue.
I was wondering if there is a way to fix this
www.lencr.org
sends the long chain. www.explogroup.ca
is using the short chain. Have you tried using the long chain? Was there a reason you needed to use the short chain?
I'm not really familiar with the notions of short chain and long chain . So there is no reason why I'm using the short chain, and I think I didn't try to use the long one.
What do I have to do to use the long chain please ?
(I read the following article Providing a longer certificate chain by default to understand what a long chain is, but do I have it and am using the wrong file, and did I do something wrong when renewing ?)
The long chain is the default.
So the site has switched to using the shorter/alternate chain.
echo | openssl s_client -connect www.explogroup.ca:443 -servername www.explogroup.ca | head
verify return:1
verify return:1
depth=0 CN = explogroup.ca
verify return:1
CONNECTED(00000005)
Certificate chain
0 s:CN = explogroup.ca
If you can't access the site securely, then your client system lacks the "ISRG Root X1" trusted root cert.
Remove the --preferred-chain
option from your command. Then it should work the same for you as www.lencr.org
See:
Thanks for your answers @MikeMcQ @rg305 ,
How could I check if I'm currently using a long or a short chain ?
I try to renew without the preferred-chain and the result is currently in production, but it seems I still have the issue with the Macbook
(It was my 5th try for this domain, so now I reach the rateLimit )
@jajoe You are still using the short chain. Rudy already showed the command to check the chain your server is currently using. The post I linked to about long/short chains also shows how right at the beginning.
If one of your previous certs was for the default long chain, you could temporarily change your server def to use a set from the /etc/letsencrypt/archive/...
folder. Make sure to update your server def back to the live
version once you finish.
You can check the chains for a local file a variety of ways - google has many - usually based on a script. But, this works for me:
openssl crl2pkcs7 -nocrl -certfile /etc/letsencrypt/archive/your-folder-name-here/fullchainX.pem | openssl pkcs7 -print_certs -noout
Iterate through each fullchain file until you find one using the long chain and use it and the related key/cert files as needed.
You really should read the "Long and Short Chains Explained" article I linked to previously. You should understand the tradeoffs involved between the two.
You can also make these chains by hand but I would not recommend that until you understand them well.
I found something in the archive, regarding https://decoder.link/sslchecker/explogroup.ca/443 (I tested too with the command shared by Rudy) things seem to be ok. Ok with Safari on my Macbook too !
I'm going to ask some users to check with their devices, but I think the issue is fixed now.
Thank you all for your help
Hello,
I came across this thread after trying to use --preferred-chain "ISRG Root X1" without any effect .
in certbot 1.7 (python 3.5)
on debian stretch
I updated to python 3.7
certbot to 1.21
now it works
