My domain is:cs.isatel.tj
I ran this command:bbb-conf -check
It produced this output: Potential problems described below
Do you own isatel.tj or are they your hosting provider? Possibly self hosted?
There is DNS records for isatel.tj but not for the subdomain cs.isatel.tj.
Do you have your own registered domain name?
Do you have a publicly accessible IP address?
If so youâll need to configure that IP in your network settings
192.168.XX.XXX lives in what is called âprivate IPâ space. As such it cannot be used to access your website/server or obtain a certificate.
These things need to be setup correctly to move forward.
Someone will correct me if I am in error, I guarantee it!
OR
If you do own this name and do need to only use it internally and somehow require a valid cert, you can try using DNS authentication - HTTP authentication requires a valid Internet accessible IP.
Thanks for the answer.
I work in a VMware virtual machine. This is my trial version. I created a domain name for myself in the hosts folder but I donât know if this will work. Will the server in the virtual machine work?
