I did a quick look (TDS right?) and did not see anything obvious. Except that your IP is dynamic and you need a business account for static IP. Do you have a bus grade account?
They also have Hacker Protect service. If you have that maybe it is too aggressive?
rg305
April 26, 2022, 2:59am
42
Who would protect Hackers!?!?!?
LOL
Good one! Actually, it's Hacker Alert (not sure that's better)
I do not have a bus grade account, and I also don't have this "hacker protect/alert" service lol
oh sorry,
the hardware is a Raspberry Pi 3 connected to the internet via ethernet to my router
I am using ssh to connect to the server (and this site) from a windows 10 desktop
rg305
April 26, 2022, 3:08am
47
From Win10, show:
http://192.168.4.60/
rg305
April 26, 2022, 3:10am
49
OK
So "the problem" is not in the Pi.
rg305
April 26, 2022, 3:13am
50
On Pi, show:
find / -name snakeoil*
# Self signed certificates generated by the ssl-cert package
ssl_certificate /etc/ssl/certs/ssl-cert-snakeoil.pem;
ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key;
rg305
April 26, 2022, 3:18am
54
Update this file to this:
# configuration file /etc/nginx/sites-enabled/matrix.corkboard.wtf:
server { #HTTP
server_name matrix.corkboard.wtf;
location ^/(?!\.well-known) { # skip challenge requests
return 301 https://$host$request_uri; # send all requests to HTTPS
}# location
root /new/dedicated/challenge/path; # path for challenge requests
server { #HTTPS
listen 443;
proxy_pass http://localhost:8008;
#ssl_certificate /etc/letsencrypt/live/matrix.corkboard.wtf/fullchain.pem;
#ssl_certificate_key /etc/letsencrypt/live/matrix.corkboard.wtf/privkey.pem;
rg305
April 26, 2022, 3:19am
55
NOTE:
is something you need to create (and change to a real path)
nginx is now giving errors
2022/04/26 03:28:55 [emerg] 9518#9518: cannot load certificate "/etc/ssl/certs/ssl-cert-snakeoil.pem": BIO_new_file() failed (SSL: error:80000002:system library::No such file or directory:calling fopen(/etc/ssl/certs/ssl-cert-snakeoil.pem, r) error:10000080:BIO routines::no such file)
ubuntu@ubuntu:~$ sudo nginx
nginx: [emerg] cannot load certificate "/etc/ssl/certs/ssl-cert-snakeoil.pem": BIO_new_file() failed (SSL: error:80000002:system library::No such file or directory:calling fopen(/etc/ssl/certs/ssl-cert-snakeoil.pem, r) error:10000080:BIO routines::no such file)
rg305
April 26, 2022, 3:34am
58
OK, just rem out those two line:
#ssl_certificate /etc/ssl/certs/ssl-cert-snakeoil.pem;
#ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key;
Lines have been removed, what should I do now?
