My domain is: adonax.com
I ran this command: certbox certificates
fgphil@ladonax:~$ sudo certbot certificates
[sudo] password for fgphil:
Found the following certs:
Certificate Name: adonax.com
Serial Number: 62852ef394d5bffedd61b75a5aff937e2fb
Key Type: RSA
Identifiers: adonax.com hexara.com leviaphon.com www.adonax.com www.hexara.com www.leviaphon.com
Expiry Date: 2026-03-20 05:24:51+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/adonax.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/adonax.com/privkey.pem
My web server is (include version): apache2
The operating system my web server runs on is (include version): Ubuntu 22.04.5 LTS (GNU/Linux 6.14.3-x86_64-linode168 x86_64)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 5.2.2
Yesterday I restored my linode remote server from a backup dated in August, 2025. Today, Thunderbird is showing my Certificate to be an old one (expired in October, 2025). I was receiving emails up to yesterday. Now, Thunderbird is not connecting, citing an expired certificate.
Thunderbird is configured to use port 993. I tested access to port 993 with sslscan --show-certificate from my client computer and it displayed the same outdated certificate held by Thunderbird.
I also checked the certificate, using SSH, from the remote server with the command certbot certificates. This displayed the info above--showing a Certificate that has different dates, ones that have not expired.
I also tried sudo certbot renew but received the message that the current certificate is valid and it did not execute the renewal.
Is it okay in this case to "force" a renewal of the Certificate? sudo certbot --force-renewal Would this update whatever the communication chain is between the stored cert in my remote server and its access via port 993? Is there a particular form of the command I should use?
Am trying to be careful!
