Plesk settings not working
i setup in my Plesk SSL by Let’s Encrypt but it start with green ssl and go than to yellow and not secured?
My domain is: as example: https://bespaarbelasting.com
You are referencing some insecure resources: some images are loaded over http:// URLs when they should be https://. You need to update the URLs or, if secure versions of those images are not available, remove them. Check https://www.whynopadlock.com/results/ab9d5d56-3209-459e-91f9-83c74c2f66f0 for details.
