kimi4
21
I entered this command but nothing heppens.
By the way, is this OK?
root@OMV:~# lsof -iTCP -sTCP:LISTEN -P
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
rpcbind 472 root 8u IPv4 16107 0t0 TCP *:111 (LISTEN)
rpcbind 472 root 11u IPv6 16110 0t0 TCP *:111 (LISTEN)
smbd 654 root 34u IPv6 17563 0t0 TCP *:445 (LISTEN)
smbd 654 root 35u IPv6 17564 0t0 TCP *:139 (LISTEN)
smbd 654 root 36u IPv4 17565 0t0 TCP *:445 (LISTEN)
smbd 654 root 37u IPv4 17566 0t0 TCP *:139 (LISTEN)
transmiss 812 debian-transmission 14u IPv4 15353 0t0 TCP *:9091 (LISTEN)
transmiss 812 debian-transmission 15u IPv4 15354 0t0 TCP *:51413 (LISTEN)
transmiss 812 debian-transmission 16u IPv6 15356 0t0 TCP *:51413 (LISTEN)
sshd 823 root 3u IPv4 32258 0t0 TCP *:22 (LISTEN)
sshd 823 root 4u IPv6 32260 0t0 TCP *:22 (LISTEN)
nginx 902 root 8u IPv4 19589 0t0 TCP *:80 (LISTEN)
nginx 903 www-data 8u IPv4 19589 0t0 TCP *:80 (LISTEN)
nginx 904 www-data 8u IPv4 19589 0t0 TCP *:80 (LISTEN)
nginx 905 www-data 8u IPv4 19589 0t0 TCP *:80 (LISTEN)
docker-pr 1355 root 4u IPv6 20906 0t0 TCP *:8080 (LISTEN)
docker-pr 1368 root 4u IPv6 19228 0t0 TCP *:444 (LISTEN)
docker-pr 1383 root 4u IPv6 20921 0t0 TCP *:3306 (LISTEN)
cupsd 31470 root 9u IPv4 461582 0t0 TCP *:631 (LISTEN)
cupsd 31470 root 10u IPv6 461583 0t0 TCP *:631 (LISTEN)
There is no apache listening port 443.
rg305
22
Yes, I see now that was my mistake - it is nginx that is listening on 80.
Try:
grep -Eri 'server_name|log|error' /etc/nginx
kimi4
23
root@OMV:~# grep -Eri 'server_name|log|error' /etc/nginx
/etc/nginx/openmediavault-webgui.d/security.conf:# http://blogs.msdn.com/b/ie/archive/2008/07/02/ie8-security-part-v-comprehensive-protection.aspx
/etc/nginx/openmediavault-webgui.d/security.conf:# http://blogs.msdn.com/b/ieinternals/archive/2011/01/31/controlling-the-internet-explorer-xss-filter-with-the-x-xss-protection-http-header.aspx
/etc/nginx/sites-available/openmediavault-webgui: server_name openmediavault-webgui;
/etc/nginx/sites-available/openmediavault-webgui: error_log /var/log/nginx/openmediavault-webgui_error.log error;
/etc/nginx/sites-available/openmediavault-webgui: access_log /var/log/nginx/openmediavault-webgui_access.log combined;
/etc/nginx/sites-available/openmediavault-webgui: error_page 404 = /404.php;
/etc/nginx/sites-available/default: server_name _;
/etc/nginx/sites-available/default:# server_name example.com;
/etc/nginx/fastcgi.conf:fastcgi_param SERVER_NAME $server_name;
/etc/nginx/nginx.conf: # server_names_hash_bucket_size 64;
/etc/nginx/nginx.conf: # server_name_in_redirect off;
/etc/nginx/nginx.conf: # Logging Settings
/etc/nginx/nginx.conf: access_log /var/log/nginx/access.log;
/etc/nginx/nginx.conf: error_log /var/log/nginx/error.log;
/etc/nginx/scgi_params:scgi_param SERVER_NAME $server_name;
/etc/nginx/uwsgi_params:uwsgi_param SERVER_NAME $server_name;
/etc/nginx/fastcgi_params:fastcgi_param SERVER_NAME $server_name
rg305
24
Try reviewing these log file:
access_log:
error_log:
kimi4
25
Have already tried. Both are empty.
rg305
26
Then we may be looking in the wrong place…
If LE is running inside docker, then we are most likely looking in the wrong place.
But now I see that there is a docker instance on port 8080 + 444
Is that where LE runs?
Is that where you need the cert?
kimi4
27
Yes, it runs inside Docker.
I can't say for sure. I'm just trying to setup Nextcloud folowing this video https://youtu.be/TkjAcp8q0W0
rg305
28
So the Nextcloud system is the one that needs the cert.
If you can run certbot on that system, then leave the redirection on the other.
You could get a cert from the Nextcould system using --webroot
system
Closed
29
