Please help- certificate expiring tomorrow.
CentOS - running nginx
Last week updated the centos using yum update. The certificates are set to renew automatically with crontab and was happily working before the update. Now my crontab has switched back to its default content and when I try the command it fails with error
[root@api ~]# /opt/letsencrypt/letsencrypt-auto renew
Processing /etc/letsencrypt/renewal/api.mydomain.com.conf
http-01 challenge for api.mydomain.com
Waiting for verification…
Unable to clean up challenge directory /usr/share/nginx/html/.well-known/acme-challenge
Attempting to renew cert from /etc/letsencrypt/renewal/api.mydomain.com.conf produced an unexpected error: Failed authorization procedure. api.mydomain.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://api.mydomain.com/.well-known/acme-challenge/Eyot1ulsp2IjkJ3kyjUGkUJ5328Fp0mr1oS3AKOVd5w: Timeout. Skipping.
/etc/letsencrypt/live/api.mydomain.com/fullchain.pem (failure)
Domain: api.mydomain.com
Type: connection
Detail: Fetching
TimeoutTo fix these errors, please make sure that your domain name was
[root@api ~]#
I can telnet on port 80 to this server.
Couple of other things I have noticed after the update is
- Status: Connection attempt failed with “ECONNREFUSED - Connection refused by server”.
- The crontab is not the same before the update, it lost all the configs I have made.
Please help
