Pip Problem when running cerbot-auto
Hello, I recently tried running the cerbot-auto file in kali linux. when it starts creating a virtual environment it fails and at the end of the log, says I’m using pip 8.0.3 and pip 9.0.1 is available and i should upgrade using >>pip install --upgrade pip
but unfortunately it says I already am up to date. I didn’t have much luck looking up the issue but if you can help it would be appreciated
did you try sudo apt-get dist-upgrade ?
