is there any way to automate the certificate validation behind a load balancer like pfsense ?
thanks
thanks
Hi @phil123456
Yes. If you search for load balancer in the forums this has been discussed a few times with suggested approaches.
Andrei
people go all over the place so I was trying to get a simple answer
hi @phil123456
If you want a simple answer then I would suggest thinking about the problem and phrasing it better.
I am playing with PFSense this weekend so will contribute what I find
Andrei
