Earlier when @MikeMcQ mentioned that I was able to fully reproduce OP's problem, I realized that I also had the same problem. So I spent over 12 hours yesterday and 3 hours this morning confirming the problem and fixing it.
One thing that became apparent during my testing is that there is a distinction between the original acme.sh working directory and the certificate files exported by pfSense.
Most operators naturally work from /conf/acme/ because it is persistent and survives reboots. However, the original certificate artifacts generated by acme.sh are stored in:
/tmp/acme/<domain>/<domain>/
In my case, the difference was significant:
grep -c "BEGIN CERTIFICATE" \
/tmp/acme/yachats-gardens.com/yachats-gardens.com/fullchain.cer
returned:
4
while:
/cf/conf/acme/yachats-gardens.com.fullchain
returned:
2
My deployment script was pulling certificates from /cf/conf/acme/, so it was faithfully deploying the 2-certificate chain found there. The deployment process on the destination server was working correctly; it was simply being given a different file than the one originally produced by acme.sh.
The solution was to use the original fullchain.cer from the acme.sh working directory and deploy that file unchanged. Once I did that, the complete 4-certificate chain was presented correctly, OpenSSL validation succeeded, and SSL Labs reported an A+ configuration.
The key is that if you're troubleshooting chain-related issues, verify the contents of the original acme.sh files in /tmp/acme/... and compare them to the exported files you're actually deploying. In my case, the difference between those two locations explained the entire issue.
Examples:
OpenSSL s_client output from external host (ns1)
root@ns1:~) ~>> openssl s_client -connect yachats-gardens.com:443 -servername yachats-gardens.com -showcerts </dev/null
CONNECTED(00000003)
depth=3 C = US, O = Internet Security Research Group, CN = ISRG Root X2
verify return:1
depth=2 C = US, O = ISRG, CN = Root YE
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = YE2
verify return:1
depth=0
verify return:1
Certificate chain
0 s:
i:C = US, O = Let's Encrypt, CN = YE2
a:PKEY: id-ecPublicKey, 256 (bit); sigalg: ecdsa-with-SHA384
v:NotBefore: May 30 20:37:52 2026 GMT; NotAfter: Jun 6 12:37:51 2026 GMT
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
1 s:C = US, O = Let's Encrypt, CN = YE2
i:C = US, O = ISRG, CN = Root YE
a:PKEY: id-ecPublicKey, 384 (bit); sigalg: ecdsa-with-SHA384
v:NotBefore: Sep 3 00:00:00 2025 GMT; NotAfter: Sep 2 23:59:59 2028 GMT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2 s:C = US, O = ISRG, CN = Root YE
i:C = US, O = Internet Security Research Group, CN = ISRG Root X2
v:NotBefore: May 13 00:00:00 2026 GMT; NotAfter: Sep 2 23:59:59 2032 GMT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3 s:C = US, O = Internet Security Research Group, CN = ISRG Root X2
a:PKEY: id-ecPublicKey, 384 (bit); sigalg: RSA-SHA256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Server certificate
subject=
issuer=C = US, O = Let's Encrypt, CN = YE2
Peer signing digest: SHA256
Peer signature type: ECDSA
Server Temp Key: X25519, 253 bits
SSL handshake has read 3753 bytes and written 401 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 256 bit
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
DONE
</details>
Hopefully that helps narrow the troubleshooting path for the OP and anyone else experimenting with short-lived certificates.
