Hello,
I am requesting short-lived IP address certificates (profile "shortlived") with Posh-ACME 4.35.0 on Windows Server 2025 / IIS, using http-01 (webroot).
Validation succeeds and finalize is accepted, but every POST-as-GET to the order URL returns 404 "No order for ID ..." for 30+ minutes, so the client can never see the "valid" status or the certificate URL. If I call finalize again, the server answers 'Order's status ("valid") is not acceptable for finalization', so the order is clearly valid and the certificate was issued, but I cannot download it.
Account: https://acme-v02.api.letsencrypt.org/acme/acct/3936153872
Affected orders:
- 577987280032 (identifiers: 81.16.120.70, jtkala.ir) - created 2026-11-04 ~07:34 UTC, finalized ~07:35 UTC
- 577943525332 (identifier: 81.16.120.70) - created 2026-11-04 ~05:06 UTC, finalized ~05:40 UTC
- 576393575572 (identifier: 81.16.120.70) - 2026-10-31, same "No order for ID" error
The authorization URLs of these orders answer correctly (status valid); only the order URL returns 404.
On 2026-10-31 one order (576416159932) became readable after ~10 minutes, but today none did.
Is this the replica lag ("404 bug")? Could you check the account, and is there a way to retrieve the certificate URLs of the valid orders above?
Thank you.
