ranch
1
Followed the instructions on /certbot.eff.org/lets-encrypt/debianstretch-nginx to install on Debian 9.
This is as far I could get to:
sudo apt update
sudo apt install snapd
Processing triggers for systemd (232-25)
sudo snap install --classic certbot
certbot 10.78 MB / 47.49 MB [==============================>------HANGS here
rg305
2
Is there anything shown by:
sudo apt list --upgradable
READERS: Get involved. Be heard. Do your part with: If you read something you like, then like it
_az
3
Could you share where your server is hosted/what your ISP is?
This could be an instance of https://forum.snapcraft.io/t/extremely-slow-snap-downloads/4668. If there is a networking problem with the snap download servers, it would be helpful to be able to know where you're connecting from.
system
Closed
4
