That’s not a Letsencrypt certificate.
Are there other instances running?
There must be urls with that certificate so you can find the running instance.
No other instances.
root@mail1:~# sudo grep -r /etc/ssl/private /etc
/etc/postfix/main.cf:#smtpd_tls_cert_file = /etc/ssl/private/fullchain.pem
/etc/postfix/main.cf:smtpd_tls_cert_file = /etc/ssl/private/fullchain.pem
/etc/postfix/main.cf:#smtpd_tls_key_file = /etc/ssl/private/privkey.pem
/etc/postfix/main.cf:smtpd_tls_key_file = /etc/ssl/private/privkey.pem
/etc/postfix/main.cf:#smtpd_tls_CAfile = /etc/ssl/private/fullchain.pem
/etc/apache2/sites-available/default-ssl.conf: SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
That's not
/etc/letsencrypt/live/mail.domain.tld/fullchain.pem
I did change it for testing purposes. I expected that maybe postfix user is not able to read it from /etc/letsencrypt/live/mail.domain.tld/fullchain.pem. So I copied the SSL files to /etc/ssl/private/ just to test. Still the same results.
In Outlook, are you using POP, IMAP, or RPC/HTTPs to connect to your mail server?
