Order's status ("valid") is not acceptable for finalization
It's using the Auths from the "new-order" Response - it's just not outputting it to the Logs - added Debug
Modified the Client to do it that way ... guess it would be easier to user another Client than adopting this one ... lol ... anyway ... it's interesting to learn more out the Protocoll ... :wink:
Here the Log for a successfull Order now:
2020-03-18 16:43:59 [info] Getting list of URLs for API
2020-03-18 16:43:59 [info] Requesting new nonce for client communication
2020-03-18 16:44:00 [info] Account already registered. Continuing.
2020-03-18 16:44:00 [info] Sending registration to letsencrypt server
2020-03-18 16:44:00 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/new-acct
2020-03-18 16:44:01 [info] Account: https://acme-v02.api.letsencrypt.org/acme/acct/accid
2020-03-18 16:44:01 [info] Starting certificate generation process for domains
2020-03-18 16:44:01 [info] Requesting challenge for demosystem.ortsinfo.at.in.futurecms.at, www.demosystem.ortsinfo.at.in.futurecms.at, demosystem.ortsinfo.at.ex.futurecms.at, www.demosystem.ortsinfo.at.ex.futurecms.at, demosystem.ortsinfo.at.ex.ortsinfo.at, www.demosystem.ortsinfo.at.ex.ortsinfo.at, demosystem.ortsinfo.at.dev.futurecms.at, www.demosystem.ortsinfo.at.dev.futurecms.at
2020-03-18 16:44:01 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/new-order
2020-03-18 16:44:03 [info] Order Authorizations: Array
    [0] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672771
    [1] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672778
    [2] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672789
    [3] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672798
    [4] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672801
    [5] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672808
    [6] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672809
    [7] => https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672823
2020-03-18 16:44:03 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/order/2188868/2698213138
2020-03-18 16:44:03 [info] Order Status - Response: Array
    [status] => pending
    [expires] => 2020-03-25T15:44:02Z
    [identifiers] => Array
            [0] => Array
                    [type] => dns
                    [value] => demosystem.ortsinfo.at.dev.futurecms.at
            [1] => Array
                    [type] => dns
                    [value] => demosystem.ortsinfo.at.ex.futurecms.at
            [2] => Array
                    [type] => dns
                    [value] => demosystem.ortsinfo.at.ex.ortsinfo.at
            [3] => Array
                    [type] => dns
                    [value] => demosystem.ortsinfo.at.in.futurecms.at
            [4] => Array
                    [type] => dns
                    [value] => www.demosystem.ortsinfo.at.dev.futurecms.at
            [5] => Array
                    [type] => dns
                    [value] => www.demosystem.ortsinfo.at.ex.futurecms.at
            [6] => Array
                    [type] => dns
                    [value] => www.demosystem.ortsinfo.at.ex.ortsinfo.at
            [7] => Array
                    [type] => dns
                    [value] => www.demosystem.ortsinfo.at.in.futurecms.at
    [authorizations] => Array
    [finalize] => https://acme-v02.api.letsencrypt.org/acme/finalize/2188868/2698213138
2020-03-18 16:44:03 [info] Auth Nr 1
2020-03-18 16:44:03 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672771
2020-03-18 16:44:04 [info] Got challenge token for demosystem.ortsinfo.at.dev.futurecms.at
2020-03-18 16:44:04 [info] Token for demosystem.ortsinfo.at.dev.futurecms.at saved at /path/to/.well-known/acme-challenge/LnSNNh2Hzr-Q6ZBqzypZ-YjPuPLf8MR8CWhE8_gZxxA and should be available at http://demosystem.ortsinfo.at.dev.futurecms.at/.well-known/acme-challenge/LnSNNh2Hzr-Q6ZBqzypZ-YjPuPLf8MR8CWhE8_gZxxA
2020-03-18 16:44:04 [info] Sending request to challenge
2020-03-18 16:44:04 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672771/KC0IZg
2020-03-18 16:44:05 [info] Auth Nr 2
2020-03-18 16:44:05 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672778
2020-03-18 16:44:06 [info] Got challenge token for demosystem.ortsinfo.at.ex.futurecms.at
2020-03-18 16:44:06 [info] Token for demosystem.ortsinfo.at.ex.futurecms.at saved at /path/to/.well-known/acme-challenge/mhtt2KrIRxwKoZPlFj-SZcOtZJeld2Ejsg_-HyTEez4 and should be available at http://demosystem.ortsinfo.at.ex.futurecms.at/.well-known/acme-challenge/mhtt2KrIRxwKoZPlFj-SZcOtZJeld2Ejsg_-HyTEez4
2020-03-18 16:44:06 [info] Sending request to challenge
2020-03-18 16:44:06 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672778/ae892A
2020-03-18 16:44:07 [info] Auth Nr 3
2020-03-18 16:44:07 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672789
2020-03-18 16:44:08 [info] Got challenge token for demosystem.ortsinfo.at.ex.ortsinfo.at
2020-03-18 16:44:08 [info] Token for demosystem.ortsinfo.at.ex.ortsinfo.at saved at /path/to/.well-known/acme-challenge/CadbtMDtWQSH33LjTQGhwStm-Whg9xXH13YQJvnRzh8 and should be available at http://demosystem.ortsinfo.at.ex.ortsinfo.at/.well-known/acme-challenge/CadbtMDtWQSH33LjTQGhwStm-Whg9xXH13YQJvnRzh8
2020-03-18 16:44:08 [info] Sending request to challenge
2020-03-18 16:44:08 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672789/4gPRrg
2020-03-18 16:44:09 [info] Auth Nr 4
2020-03-18 16:44:09 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672798
2020-03-18 16:44:10 [info] Got challenge token for demosystem.ortsinfo.at.in.futurecms.at
2020-03-18 16:44:10 [info] Token for demosystem.ortsinfo.at.in.futurecms.at saved at /path/to/.well-known/acme-challenge/HsoJOI9LG67zpJ_Znr-sRZ1owuPt-YeOBoqmxf6d4tY and should be available at http://demosystem.ortsinfo.at.in.futurecms.at/.well-known/acme-challenge/HsoJOI9LG67zpJ_Znr-sRZ1owuPt-YeOBoqmxf6d4tY
2020-03-18 16:44:10 [info] Sending request to challenge
2020-03-18 16:44:10 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672798/0x7eGw
2020-03-18 16:44:11 [info] Auth Nr 5
2020-03-18 16:44:11 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672801
2020-03-18 16:44:12 [info] Got challenge token for www.demosystem.ortsinfo.at.dev.futurecms.at
2020-03-18 16:44:12 [info] Token for www.demosystem.ortsinfo.at.dev.futurecms.at saved at /path/to/.well-known/acme-challenge/jjK1Rtc468zNMNHk5YfHU097a2AEzQuPEqc5Oq46r68 and should be available at http://www.demosystem.ortsinfo.at.dev.futurecms.at/.well-known/acme-challenge/jjK1Rtc468zNMNHk5YfHU097a2AEzQuPEqc5Oq46r68
2020-03-18 16:44:12 [info] Sending request to challenge
2020-03-18 16:44:12 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672801/3vZq9g
2020-03-18 16:44:13 [info] Auth Nr 6
2020-03-18 16:44:13 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672808
2020-03-18 16:44:13 [info] Got challenge token for www.demosystem.ortsinfo.at.ex.futurecms.at
2020-03-18 16:44:13 [info] Token for www.demosystem.ortsinfo.at.ex.futurecms.at saved at /path/to/.well-known/acme-challenge/kuxw8tsFdnytdSjZnZH8_wNSUfmVvxNGki4KQRtLBwc and should be available at http://www.demosystem.ortsinfo.at.ex.futurecms.at/.well-known/acme-challenge/kuxw8tsFdnytdSjZnZH8_wNSUfmVvxNGki4KQRtLBwc
2020-03-18 16:44:13 [info] Sending request to challenge
2020-03-18 16:44:13 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672808/kfl5dA
2020-03-18 16:44:14 [info] Auth Nr 7
2020-03-18 16:44:14 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672809
2020-03-18 16:44:15 [info] Got challenge token for www.demosystem.ortsinfo.at.ex.ortsinfo.at
2020-03-18 16:44:15 [info] Token for www.demosystem.ortsinfo.at.ex.ortsinfo.at saved at /path/to/.well-known/acme-challenge/DfRGfT6Uo5t1tgexf71c32gCL-pJ-w65eZS9bFVwutE and should be available at http://www.demosystem.ortsinfo.at.ex.ortsinfo.at/.well-known/acme-challenge/DfRGfT6Uo5t1tgexf71c32gCL-pJ-w65eZS9bFVwutE
2020-03-18 16:44:15 [info] Sending request to challenge
2020-03-18 16:44:15 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672809/-2SQ6A
2020-03-18 16:44:16 [info] Auth Nr 8
2020-03-18 16:44:16 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/authz-v3/3430672823
2020-03-18 16:44:17 [info] Got challenge token for www.demosystem.ortsinfo.at.in.futurecms.at
2020-03-18 16:44:17 [info] Token for www.demosystem.ortsinfo.at.in.futurecms.at saved at /path/to/.well-known/acme-challenge/nJGlhUHIeI7q7bzDEQ36BUMsgNkq_ZjbqmSwQvC4HhA and should be available at http://www.demosystem.ortsinfo.at.in.futurecms.at/.well-known/acme-challenge/nJGlhUHIeI7q7bzDEQ36BUMsgNkq_ZjbqmSwQvC4HhA
2020-03-18 16:44:17 [info] Sending request to challenge
2020-03-18 16:44:17 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672823/aKVjZg
2020-03-18 16:44:18 [info] Sleeping 5s before checking challenges
2020-03-18 16:44:23 [info] Auth Verify Nr 1
2020-03-18 16:44:23 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672771/KC0IZg
2020-03-18 16:44:24 [info] Verification pending, sleeping 1s
2020-03-18 16:44:25 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672771/KC0IZg
2020-03-18 16:44:26 [info] Verification pending, sleeping 5s
2020-03-18 16:44:31 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672771/KC0IZg
2020-03-18 16:44:32 [info] Verification pending, sleeping 10s
2020-03-18 16:44:42 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672771/KC0IZg
2020-03-18 16:44:42 [info] Verification ended with status: valid
2020-03-18 16:44:42 [info] Token Path: /path/to/.well-known/acme-challenge/LnSNNh2Hzr-Q6ZBqzypZ-YjPuPLf8MR8CWhE8_gZxxA
2020-03-18 16:44:42 [info] Auth Verify Nr 2
2020-03-18 16:44:42 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672778/ae892A
2020-03-18 16:44:43 [info] Verification ended with status: valid
2020-03-18 16:44:43 [info] Token Path: /path/to/.well-known/acme-challenge/mhtt2KrIRxwKoZPlFj-SZcOtZJeld2Ejsg_-HyTEez4
2020-03-18 16:44:43 [info] Auth Verify Nr 3
2020-03-18 16:44:43 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672789/4gPRrg
2020-03-18 16:44:44 [info] Verification ended with status: valid
2020-03-18 16:44:44 [info] Token Path: /path/to/.well-known/acme-challenge/CadbtMDtWQSH33LjTQGhwStm-Whg9xXH13YQJvnRzh8
2020-03-18 16:44:44 [info] Auth Verify Nr 4
2020-03-18 16:44:44 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672798/0x7eGw
2020-03-18 16:44:45 [info] Verification ended with status: valid
2020-03-18 16:44:45 [info] Token Path: /path/to/.well-known/acme-challenge/HsoJOI9LG67zpJ_Znr-sRZ1owuPt-YeOBoqmxf6d4tY
2020-03-18 16:44:45 [info] Auth Verify Nr 5
2020-03-18 16:44:45 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672801/3vZq9g
2020-03-18 16:44:46 [info] Verification ended with status: valid
2020-03-18 16:44:46 [info] Token Path: /path/to/.well-known/acme-challenge/jjK1Rtc468zNMNHk5YfHU097a2AEzQuPEqc5Oq46r68
2020-03-18 16:44:46 [info] Auth Verify Nr 6
2020-03-18 16:44:46 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672808/kfl5dA
2020-03-18 16:44:47 [info] Verification ended with status: valid
2020-03-18 16:44:47 [info] Token Path: /path/to/.well-known/acme-challenge/kuxw8tsFdnytdSjZnZH8_wNSUfmVvxNGki4KQRtLBwc
2020-03-18 16:44:47 [info] Auth Verify Nr 7
2020-03-18 16:44:47 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672809/-2SQ6A
2020-03-18 16:44:48 [info] Verification ended with status: valid
2020-03-18 16:44:48 [info] Token Path: /path/to/.well-known/acme-challenge/DfRGfT6Uo5t1tgexf71c32gCL-pJ-w65eZS9bFVwutE
2020-03-18 16:44:48 [info] Auth Verify Nr 8
2020-03-18 16:44:48 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/3430672823/aKVjZg
2020-03-18 16:44:49 [info] Verification ended with status: valid
2020-03-18 16:44:49 [info] Token Path: /path/to/.well-known/acme-challenge/nJGlhUHIeI7q7bzDEQ36BUMsgNkq_ZjbqmSwQvC4HhA
2020-03-18 16:44:49 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/order/2188868/2698213138
2020-03-18 16:44:49 [info] Order Status before wait - Response: Array
    [status] => ready
            [0] => Array
                    [type] => dns
            [1] => Array
                    [type] => dns
            [2] => Array
                    [type] => dns
            [3] => Array
                    [type] => dns
            [4] => Array
                    [type] => dns
            [5] => Array
                    [type] => dns
            [6] => Array
                    [type] => dns
            [7] => Array
                    [type] => dns
2020-03-18 16:44:49 [info] Sleeping 5s to be sure Order Status is READY
2020-03-18 16:44:54 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/order/2188868/2698213138
2020-03-18 16:44:55 [info] Order Status after wait - Response: Array
    [status] => ready
            [0] => Array
                    [type] => dns
            [1] => Array
                    [type] => dns
            [2] => Array
                    [type] => dns
            [3] => Array
                    [type] => dns
            [4] => Array
                    [type] => dns
            [5] => Array
                    [type] => dns
            [6] => Array
                    [type] => dns
            [7] => Array
                    [type] => dns
2020-03-18 16:44:55 [info] Firing finalization request to: https://acme-v02.api.letsencrypt.org/acme/finalize/2188868/2698213138
2020-03-18 16:44:55 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/finalize/2188868/2698213138
2020-03-18 16:44:56 [info] Finalize Response: Array
    [status] => valid
            [0] => Array
                    [type] => dns
            [1] => Array
                    [type] => dns
            [2] => Array
                    [type] => dns
            [3] => Array
                    [type] => dns
            [4] => Array
                    [type] => dns
            [5] => Array
                    [type] => dns
            [6] => Array
                    [type] => dns
            [7] => Array
                    [type] => dns
    [certificate] => https://acme-v02.api.letsencrypt.org/acme/cert/03706ad13696493d92c3ae5f89f6e4b8475a
2020-03-18 16:44:56 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/cert/03706ad13696493d92c3ae5f89f6e4b8475a
2020-03-18 16:44:57 [info] Got certificate! YAY!
2020-03-18 16:44:57 [info] Saving fullchain.pem
2020-03-18 16:44:57 [info] Saving cert.pem
2020-03-18 16:44:57 [info] Saving chain.pem
2020-03-18 16:44:57 [info] Sending signed request to https://acme-v02.api.letsencrypt.org/acme/order/2188868/2698213138
2020-03-18 16:44:58 [info] Order Status - Response: Array
    [status] => valid
            [0] => Array
                    [type] => dns
            [1] => Array
                    [type] => dns
            [2] => Array
                    [type] => dns
            [3] => Array
                    [type] => dns
            [4] => Array
                    [type] => dns
            [5] => Array
                    [type] => dns
            [6] => Array
                    [type] => dns
            [7] => Array
                    [type] => dns
    [certificate] => https://acme-v02.api.letsencrypt.org/acme/cert/xxxxx
2020-03-18 16:44:58 [info] Done !!§§!
Now your log looks better.
Challenge created -> “please check that”.
First challenge -> you have to wait.
Next challenges -> all are valid.
alright - sounds good … :wink:
Also adopted the last part now … check loop for STATUS READY before firing the finalization Request and not a simple sleep() anymore …
let’s see if those Errors come up again … if yes … we should have all the required Debug Infos I guess …
Thank you both for your help :wink:
