i used one click instal of openlite speed and lets encrypt.
the following file has been created in cron
0 */12 * * * root test -x /usr/bin/certbot -a ! -d /run/systemd/system && perl -e 'sleep int(rand(43200))' && ce$ --deploy-hook "/usr/local/lsws/bin/lswsctrl restart"
the certificate gets renewed but openlitespeed needs a manual restart
when i run
~# certbot --force-renewal
i get an error so wondering if this error is somehow preventing the restart.
Certbot doesn't know how to automatically configure the web server on this system. However, it can still get a certificate for you. Please run "certbot certonly" to do so. You'll need to manually configure your web server to use the resulting certificate.
The script is there and that's what i have to do manually to restart the server after the update.
Is there a way to test the renew command with the hook? shoudl i test it with --force-renewal?
i tested with --dry-run and it goes fine though cycles and skips it since not renewed so all looks good. Maybe it needed some updated since i just recently updated to latest version from 0.3.
