OCSP responder problems
My nginx server gets OCSP errors for several days now. I'm not sure if the OCSP responder is unstable or never works.
Example log lines:
2021/01/07 13:11:08 [error] 20866#20866: recv() failed (110: Connection timed out) while requesting certificate status, responder: ocsp.int-x3.letsencrypt.org, peer: 23.55.163.68:80, certificate: "/etc/nginx/ssl/ipv6.ipv6-test.molitor-dietzel.de.crt"
2021/01/07 13:11:08 [error] 20866#20866: OCSP responder prematurely closed connection while requesting certificate status, responder: ocsp.int-x3.letsencrypt.org, peer: 23.55.163.68:80, certificate: "/etc/nginx/ssl/ipv6.ipv6-test.molitor-dietzel.de.crt"
2021/01/07 13:11:16 [error] 20866#20866: recv() failed (110: Connection timed out) while requesting certificate status, responder: r3.o.lencr.org, peer: 23.55.163.58:80, certificate: "/etc/nginx/ssl/bad.tlsa.molitor-dietzel.de.crt"
2021/01/07 13:11:16 [error] 20866#20866: OCSP responder prematurely closed connection while requesting certificate status, responder: r3.o.lencr.org, peer: 23.55.163.58:80, certificate: "/etc/nginx/ssl/bad.tlsa.molitor-dietzel.de.crt"
I'm assuming this is errors from your server trying to do OCSP stapling?
Can you access r3.o.lencr.org from that server? What do you see when running something like
curl -v http://r3.o.lencr.org/
Yes, I'm trying to staple the ocsp response.
The curl output:
# curl -v http://r3.o.lencr.org/
* Expire in 0 ms for 6 (transfer 0x557274b02f90)
* Expire in 1 ms for 1 (transfer 0x557274b02f90)
* Expire in 0 ms for 1 (transfer 0x557274b02f90)
* Expire in 2 ms for 1 (transfer 0x557274b02f90)
* Expire in 4 ms for 1 (transfer 0x557274b02f90)
* Expire in 3 ms for 1 (transfer 0x557274b02f90)
* Expire in 8 ms for 1 (transfer 0x557274b02f90)
* Expire in 5 ms for 1 (transfer 0x557274b02f90)
* Expire in 7 ms for 1 (transfer 0x557274b02f90)
* Expire in 9 ms for 1 (transfer 0x557274b02f90)
*   Trying 23.55.163.58...
* TCP_NODELAY set
* Expire in 149986 ms for 3 (transfer 0x557274b02f90)
* Expire in 200 ms for 4 (transfer 0x557274b02f90)
* Connected to r3.o.lencr.org (23.55.163.58) port 80 (#0)
> GET / HTTP/1.1
> Host: r3.o.lencr.org
> User-Agent: curl/7.64.0
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx
< Content-Length: 0
< Cache-Control: max-age=20211
< Expires: Thu, 07 Jan 2021 21:26:32 GMT
< Date: Thu, 07 Jan 2021 15:49:41 GMT
< Connection: keep-alive
* Connection #0 to host r3.o.lencr.org left intact
I'm thinking this may have something to do with the MTU size and the path along the way.
To see if the problem is with that destination network, you could (temporarily) try to use a different IP for ocsp.int-x3.letsencrypt.org & r3.o.lencr.org.
Here is what I get from where I am:
ocsp.int-x3.letsencrypt.org     canonical name = ocsp.int-x3.letsencrypt.org.edgesuite.net.
ocsp.int-x3.letsencrypt.org.edgesuite.net       canonical name = a771.dscq.akamai.net.
Address: 23.45.51.153
Address: 23.45.51.162
Address: 2600:1417:27::17ce:d768
Address: 2600:1417:27::17ce:d758
r3.o.lencr.org  canonical name = o.lencr.edgesuite.net.
o.lencr.edgesuite.net   canonical name = a1887.dscq.akamai.net.
Address: 23.45.51.139
Address: 23.45.51.121
Address: 2600:1417:27::17ce:d77a
Address: 2600:1417:27::17ce:d780
Any chance it might be related to this OCSP issue?
It wouldn’t be this issue; the timing doesn’t line up.
